メインコンテンツにスキップ
TaoTronics TT-SK06 Control Buttons Replacement
必要な工具と部品
  1. TaoTronics TT-SK06 Control Buttons Replacement, Front Grate: 手順 1、 2の画像 1 TaoTronics TT-SK06 Control Buttons Replacement, Front Grate: 手順 1、 2の画像 2
    • To remove the front grate of the speaker grab a metal spudger and go to the back corner of the device where the front panel curves around the device. Insert the spudger and ply apart the corner until clips release from panel. Repeat for the other side of the grate. When all clips are released pull grate off from the front of device
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. TaoTronics TT-SK06 Control Buttons Replacement: 手順 2、 3の画像 1 TaoTronics TT-SK06 Control Buttons Replacement: 手順 2、 3の画像 2 TaoTronics TT-SK06 Control Buttons Replacement: 手順 2、 3の画像 3
    • Grab two metal spudgers and insert one into the slit underneath the silver plating on the top of the device. Pry upward with the spudger until you unhook the two locks on the top. Repeat same step for the bottom of the device. When all four tabs are released, slide device out of the casing
    • Use caution when working with the metal spudger, as it can potentially damage your device.
  3. TaoTronics TT-SK06 Control Buttons Replacement, Control Buttons: 手順 3、 2の画像 1 TaoTronics TT-SK06 Control Buttons Replacement, Control Buttons: 手順 3、 2の画像 2
    • Locate the four, 6mm screws on the board on top of the device. Unscrew them with the PH0 bit on the screwdriver so that the board may be removed.
  4. TaoTronics TT-SK06 Control Buttons Replacement: 手順 4、 3の画像 1 TaoTronics TT-SK06 Control Buttons Replacement: 手順 4、 3の画像 2 TaoTronics TT-SK06 Control Buttons Replacement: 手順 4、 3の画像 3
    • Using the nylon spudger, carefully remove the board from its socket. Next detach the wires from the chip to remove the board. After board is removed replace buttons.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Niko Fabian
メンバー登録日: 03/06/16
715 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 5-7, Landers Spring 2016 UMass Dartmouth, Team 5-7, Landers Spring 2016人のメンバー
UMASSD-LANDERS-S16S5G7
3 メンバー
5のガイドは作成済み
3 件のコメント
Great guide,to repair this bluetooth speaker. I have the same speaker from another brand.It called Aiser HSR 13.It is just cheaper, than the Tao Tronics.
Dennis Feldmann - 返信
Where can I get the control button?
Charles Thompson - 返信
Where can I get the button
Kevin Loyola - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 2,307
