はじめに
If the device will not charge when plugged into an outlet, you will have to replace the charging port on the device. This is how you will replace it.
必要な工具と部品
To remove the front grate of the speaker grab a metal spudger and go to the back corner of the device where the front panel curves around the device. Insert the spudger and ply apart the corner until clips release from panel. Repeat for the other side of the grate. When all clips are released pull grate off from the front of device
Locate the slit on the back of the device and the board will be located there. Remove board from slit by using tweezers.
2 の人々がこのガイドを完成させました。
