メインコンテンツにスキップ
Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement
必要な工具と部品
  1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement, 1/10 Scale Brushed Motor: 手順 1、 3の画像 1 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement, 1/10 Scale Brushed Motor: 手順 1、 3の画像 2 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement, 1/10 Scale Brushed Motor: 手順 1、 3の画像 3
    • Remove the four screws with a Phillips #00 screwdriver.
  2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 2、 3の画像 1 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 2、 3の画像 2 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 2、 3の画像 3
    • Slowly remove the body, lifting it upward from the chassis.
    • Hold the front and back of the body with both hands when removing it.
    • Lift the body past the antenna to avoid damaging it.
  3. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 3、 3の画像 1 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 3、 3の画像 2 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 3、 3の画像 3
    • Attach your box wrench with the 7mm side facing into the rim onto the hex-nut.
    • Twist the box wrench left (counter-clockwise) and unscrew the hex-nut until it comes off.
    • Hold the tire in place to prevent the tire from spinning with your box wrench.
  4. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 4、 3の画像 1 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 4、 3の画像 2 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 4、 3の画像 3
    • Grab both the yellow and black wire as well as the green and orange wire and pull them apart.
    • The wire connectors may be difficult to remove. Do not hesitate to use more force to remove them from each other, if necessary.
    • It does not matter which wires you disconnect or connect first.
  5. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 5、 3の画像 1 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 5、 3の画像 2 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 5、 3の画像 3
    • Loosen the first screw on the motor cover using a Phillips #00 screwdriver.
    • Loosen the bottom screw next, and you will feel the motor come loose.
    • The bottom screw has more leverage on the motor, so reverse these steps when re-assembling.
    • The motor cover is black, mine is spray-painted green.
  6. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 6、 3の画像 1 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 6、 3の画像 2 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 6、 3の画像 3
    • Finish loosening the long screws with your Phillips #00 screwdriver.
    • Slowly pull the motor cover away from the gearbox, with the two long Phillips screws still inside the motor cover.
    • Pull the motor away from the gearbox.
    • Do not force the motor out. Let it slide into your hand if necessary to avoid damaging components or gears inside the gearbox.
  7. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 7、 3の画像 1 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 7、 3の画像 2 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 7、 3の画像 3
    • Gently slide your 540 motor into the gearbox. Make sure it is correctly inline with the pinion (the middle gear segment).
    • Slide the motor cover, then the long screws into the left side of the gearbox to align the motor with the gearbox.
    • Make sure all the holes to the motor cover, motor, and gearbox line up with the two long screws that hold the motor cover on.
  8. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 8、 3の画像 1 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 8、 3の画像 2 Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: 手順 8、 3の画像 3
    • Tighten the bottom screw with your Phillips #00 screwdriver.
    • Lay the buggy down and tighten the top screw next, to help ensure the motor is properly in place.
    • If you tighten the motor to the gearbox, but your pinion misaligned with the main gear, your motor will NOT move the car, which may cause damage to the motor.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Eric Traccitto
メンバー登録日: 09/20/22
181 ポイント
1ガイドが承認済み
チーム
York University, Team B-8, Allen Fall 2022 York University, Team B-8, Allen Fall 2022人のメンバー
YORK-ALLEN-F22SBG8
2 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 38
今までの合計 812
