メインコンテンツにスキップ
Tama 22 Inch Kick Drum Plastic Cover Replacement
必要な工具と部品
  1. Tama 22 Inch Kick Drum Plastic Cover Replacement, Plastic Cover: 手順 1、 1の画像 1
    • Remove any attachments of the kick drum.
    • This includes symbols, toms, and kick pedal.
    • Leave the leg supports of the kick drum attached.
  2. Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 2、 2の画像 1 Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 2、 2の画像 2
    • Turn the kick drum over so the broken plastic screen is facing up.
    • It may be beneficial to have some cushion between the floor and the drum to avoid any scratches on either object.
  3. Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 3、 2の画像 1 Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 3、 2の画像 2
    • Use a drum key tuner to loosen the bolt by rotating counterclockwise.
    • It is not necessary to completely take the bolt out from the rim.
  4. Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 4、 3の画像 1 Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 4、 3の画像 2 Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 4、 3の画像 3
    • Repeat step 3 for all bolts that surround the rim.
    • Detach the bolts from the body of the drum; however, leave them attached and hanging loosely to the rim.
    • Rotate the rim to be sure that all bolts are free.
  5. Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 5、 1の画像 1
    • With both hands, remove the rim that still has the bolts attached and place aside for further use.
  6. Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 6、 2の画像 1 Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 6、 2の画像 2
    • Remove the plastic microphone port from the drum.
    • This can be thrown away in the recycle bin.
    • Older models of a port screen tend to have a thinner screen without protection. Carelessness in handling may result in a severe cut.
  7. Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 7、 2の画像 1 Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 7、 2の画像 2
    • Place the new plastic cover port on top of the drum so it sits perfectly on it.
    • Depending which microphone port is being placed, adjust the cover so that words will be properly read when the drum is placed upright.
    • Press down on the edges of the drum cover so it is snuggled into the drum.
    • Take into consideration the position of the hole when the drum is placed upright.
  8. Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 8、 3の画像 1 Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 8、 3の画像 2 Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 8、 3の画像 3
    • Place the rim used in Step 5 back onto the drum.
    • Align the bolts so each bolt has an input that is attached to the center of the drum.
  9. Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 9、 2の画像 1 Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 9、 2の画像 2
    • Finger tighten the bolts in a clockwise motion. Do this to all of the remaining bolts that are loose.
    • Evenly tighten the bolts with the same amount of pressure.
    • For an easier experience, tighten the bolts underneath the rim rather than above the rim. See the red box location in the pictures for clarification.
  10. Tama 22 Inch Kick Drum Plastic Cover Replacement: 手順 10、 1の画像 1
    • Use the drum key to tighten the bolts in a clockwise manner.
    • Turn the drum key one full turn (360 degrees) and move to the next bolt so that the same pressure is evenly applied to each key.
    • Turning the bolts too many times may result in severe damage on the drum and its plastic cover.
終わりに
作成者
2人の作成者と共同で作成されました。
Steve Perez
メンバー登録日: 02/03/22
181 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 31-31, Harris Spring 2022 CSU Los Angeles, Team 31-31, Harris Spring 2022人のメンバー
CSULA-HARRIS-S22S31G31
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 18
今までの合計 403
