メインコンテンツにスキップ
TRS-80 Color Computer Power Cord Replacement
必要な工具と部品
  1. TRS-80 Color Computer Power Cord Replacement, Outside Casing: 手順 1、 1の画像 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Power Cord Replacement: 手順 2、 2の画像 1 TRS-80 Color Computer Power Cord Replacement: 手順 2、 2の画像 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Power Cord Replacement, Keyboard: 手順 3、 2の画像 1 TRS-80 Color Computer Power Cord Replacement, Keyboard: 手順 3、 2の画像 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Power Cord Replacement, Motherboard: 手順 4、 3の画像 1 TRS-80 Color Computer Power Cord Replacement, Motherboard: 手順 4、 3の画像 2 TRS-80 Color Computer Power Cord Replacement, Motherboard: 手順 4、 3の画像 3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Power Cord Replacement: 手順 5、 3の画像 1 TRS-80 Color Computer Power Cord Replacement: 手順 5、 3の画像 2 TRS-80 Color Computer Power Cord Replacement: 手順 5、 3の画像 3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Power Cord Replacement, Power Cord: 手順 6、 2の画像 1 TRS-80 Color Computer Power Cord Replacement, Power Cord: 手順 6、 2の画像 2
    • Remove the two 1.6 inch screws securing the transformer.
  7. TRS-80 Color Computer Power Cord Replacement: 手順 7、 1の画像 1
    • Remove the power cord's three leads from the transformer.
    • Note the orientation and color of the three leads. Make sure to replace these exactely as they were.
  8. TRS-80 Color Computer Power Cord Replacement: 手順 8、 2の画像 1 TRS-80 Color Computer Power Cord Replacement: 手順 8、 2の画像 2
    • Using needle-nose pliers, pinch the tabs of the grommet holding the power cord to the case and push the grommet out.
    • Remove the entire length of cord from the case and replace with a new one.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Christopher Paige
メンバー登録日: 01/21/11
549 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 11-24, Maness Winter 2011 Cal Poly, Team 11-24, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G24
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 2,279
