はじめに
This guide will walk you through the necessary steps for replacing the power jack on your Toshiba Satelite E45W-C4200X.
The power jack has been a common problem with the Toshiba Satellite laptops and the replacement is quick and relatively inexpensive.
Before using this guide, make sure to review the troubleshooting page to ensure this replacement is necessary.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
必要な工具と部品
Remove the ten 1 mm screws that secure the back cover using a Phillip's #1 screwdriver.
ある他の人がこのガイドを完成しました。
