メインコンテンツにスキップ
TM3D DWIN Added Screens
必要な工具と部品
  1. TM3D DWIN Added Screens, Tools Menu: 手順 1、 3の画像 1 TM3D DWIN Added Screens, Tools Menu: 手順 1、 3の画像 2 TM3D DWIN Added Screens, Tools Menu: 手順 1、 3の画像 3
    • Once your machine has booted up, from the Idle Screen, press Settings.
    • Press Tools
    • Initialize EEPROM will clear all soft data and restore the machine back to the last firmware settings installed. The screen may return to the idle screen.
    • Reset BLTouch is only valid if you have a BL Touch probe installed. This button will clear any current errors with the Probe. No movement or confirmation will occur.
    • Adjust Steps/mm will bring you to a new menu where you can calibrate each Axis' steps/mm. Pressing this will enter the Calibration screen for Steps/mm.
    • PID Tuning will bring you to a new menu where you can calibrate thermal settings. Pressing this will enter the Calibration screen for PID Tuning.
  2. TM3D DWIN Added Screens, Calibration Screens: 手順 2、 2の画像 1 TM3D DWIN Added Screens, Calibration Screens: 手順 2、 2の画像 2
    • These values are set for your machine and normally do not need modified. Edit at your own risk! However, if you feel you make a mistake, you can Initialize EEPROM from the Tools menu.
    • Calibration
    • The white boxes will all be populated with your printer's settings.
    • Probe Offset can be changed if you change the probe to nozzle relationship.
    • Steps/mm can be changed to fine tune your machine or add an aftermarket extruder. A popular bench test is a 20mm cube.
    • Calibration-PID Tuning>PID Automatic Tuning will initiate an automatic PID calibration. Enter a temperature 10 degrees over your printing temperature and press Start.
    • Calibration-PID Tuning>PID Manual Tuning will display the current saved values and allow manual adjustment.
    • After desired changes are made, press Store Settings
  3. TM3D DWIN Added Screens, Error Screens: 手順 3、 3の画像 1 TM3D DWIN Added Screens, Error Screens: 手順 3、 3の画像 2 TM3D DWIN Added Screens, Error Screens: 手順 3、 3の画像 3
    • These Error screens are hard faults and a power cycle will be necessary to clear them.
    • Thermistor Error! This is usually a wiring or component issue.
    • If reading is 0 or lower, you have an open circuit. This means 1 or both wires are not connected to maintain reasonably resistance. It could be from a broken wire or simply, an unplugged connection.
    • Heating Failed! This is sometimes a wiring or component issue.
    • This usually means a wire to the heated bed or nozzle has been damaged or unplugged but not always. It could be that you have the target temperature set to high for the available power and it is taking too long in your current environment.
    • MACHINE FAULT This is sometimes a wiring issue.
    • If an end stop (limit switch) is unplugged or isn't triggered during homing
    • Verify that all limit switches work (Serial Terminal using M119 command) and are contacted by the machine by hand.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Tiny Machines 3D
メンバー登録日: 11/16/19
2,970 ポイント
14のガイドは作成済み
チーム
Tiny Machines 3D Tiny Machines 3D人のメンバー
Community
5 メンバー
40のガイドは作成済み
10 件のコメント
This is so hot mess, looking at Ender 5 Plus firmware and screen update…..documents are all out dated and files are not correct just a hot mess and wasted 2 hours try to figure your crap out.
Chris C - 返信
What are you referring to? If you’re having issues with a firmware update, the best way to contact us is email - support@tinymachines3d.com.
https://docs.google.com/document/d/1lkhv... is where we have the latest files.
Tiny Machines 3D -
Hi
I have installed latest version of UI for CR10s Pro and Marlen 2.0.x. What is extruder value for, not defined above?
I want to know how to modify extrusion rate steps/mm thank you?
Johan Dekker - 返信
Can the screen firmware be flashed on any Ender 5 Plus? And it will just work? or does the board need firmware updates too? I’m running the Creatlity silent board
tom jones - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 73
今までの合計 11,871
