はじめに
Replacing a wheel on a TILT pro scooter is a common maintenance task that any rider should know how to do. Whether you're upgrading your wheels or replacing a damaged one, it's important to know the steps to ensure a smooth and safe ride. In this guide, we'll take you through the necessary steps to replace a wheel on your pro scooter. You'll need a few tools and a bit of patience, but with this guide, you should be able to replace your wheel in no time.
必要な工具と部品
To reassemble the wheel from the back of the scooter repeat step 1, follow the instructions similar to the front wheel.
ある他の人がこのガイドを完成しました。
