はじめに
For this guide you will remove all of the internal components in order to access the front cover.
必要な工具と部品
Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
Use your finger to move the battery cover to the side.
After removing the battery, use a Phillips #00 screwdriver to take out the 4.5mm screw directly to the right of the solar panel.
Lift the top edge of the solar panel with a finger and slide it away from the circuit board to disconnect it from the calculator.
Carefully pry the screen out of the calculator with a prying tool or spudger.
Pry the lower circuit board from the calculator by inserting a prying tool between the base of the calculator and the circuit board.
Empty the buttons into a bag or place them somewhere that they will not be lost.
Using a spudger, undo the 5 clips around the edge of the casing that connect the front cover to the calculator.
2 の人々がこのガイドを完成させました。
