メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TI-36X Pro Button Replacement
必要な工具と部品
    1. TI-36X Pro Button Replacement, Back Cover: 手順 1、 2の画像 1 TI-36X Pro Button Replacement, Back Cover: 手順 1、 2の画像 2
      • Remove the calculator's protective cover.
      • Place the calculator face down.
      FixBotに聞いてみる
      コメントを追加
    2. TI-36X Pro Button Replacement: 手順 2、 2の画像 1 TI-36X Pro Button Replacement: 手順 2、 2の画像 2
      • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
      • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
      FixBotに聞いてみる
      コメントを追加
    1. TI-36X Pro Button Replacement, Battery: 手順 3、 2の画像 1 TI-36X Pro Button Replacement, Battery: 手順 3、 2の画像 2
      • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
      • Remove the battery cover without disconnecting either end of the blue wire.
      • Use your finger to move the battery cover to the side.
      FixBotに聞いてみる
      コメントを追加
    2. TI-36X Pro Button Replacement: 手順 4、 1の画像 1
      • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
      • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
      FixBotに聞いてみる
      コメントを追加
    1. TI-36X Pro Button Replacement, Button: 手順 5、 1の画像 1
      • After removing the battery, use a Phillips #00 screwdriver to take out the 4.5mm screw directly to the right of the solar panel.
      • Do not disconnect any wires or you will need to solder them back on.
      FixBotに聞いてみる
      コメントを追加
    2. TI-36X Pro Button Replacement: 手順 6、 1の画像 1
      • Next, use a Phillips #00 screwdriver to remove the two screws located on each side of the striped ribbon between the two green circuit boards.
      FixBotに聞いてみる
      コメントを追加
    3. TI-36X Pro Button Replacement: 手順 7、 1の画像 1
      • Be careful not to scratch the gold lines on the circuit board since it may damage the circuit.
      • Carefully chisel off the 11 circular pieces that connect the lower circuit board to the calculator.
      • When reassembling the calculator, glue the lower circuit board back in place by dabbing glue into the holes that you chiseled.
      FixBotに聞いてみる
      コメントを追加
    4. TI-36X Pro Button Replacement: 手順 8、 3の画像 1 TI-36X Pro Button Replacement: 手順 8、 3の画像 2 TI-36X Pro Button Replacement: 手順 8、 3の画像 3
      • When removing the parts from the calculator be careful not to break any wires or ribbons. The solar panel, screen, and lower circuit board should remain connected throughout this guide.
      • Lift the top edge of the solar panel with a finger and slide it away from the circuit board to disconnect it from the calculator.
      • Carefully pry the screen out of the calculator with a prying tool or spudger.
      • Pry the lower circuit board from the calculator by inserting a prying tool between the base of the calculator and the circuit board.
      FixBotに聞いてみる
      コメントを追加
    5. TI-36X Pro Button Replacement: 手順 9、 1の画像 1
      • Grab one of the top corners of the gray rubber button pad and peel it off of the buttons.
      • If you turn the calculator over, all of the buttons will fall out.
      FixBotに聞いてみる
      コメントを追加
    6. TI-36X Pro Button Replacement: 手順 10、 2の画像 1 TI-36X Pro Button Replacement: 手順 10、 2の画像 2
      この手順で使用する道具:
      • Locate the button that needs replacement and lift it out of the calculator with tweezers.
      • If the buttons do fall out, use the second picture to put them back properly.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Robert Sekerak
メンバー登録日: 04/25/14
664 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-52, Amido Spring 2014 Cal Poly, Team 11-52, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G52
4 メンバー
25のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 44
今までの合計 3,076
