メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement
必要な工具と部品
  1. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement, LCD Digitizer: 手順 1、 1の画像 1
    • Twist both screws 180 degrees using a small flathead screwdriver. The arrows should be pointing to unlock. Slide the boot module down and out of the data collector.
  2. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: 手順 2、 1の画像 1
    • Remove both screws using a phillips head screwdriver. Pull the top cover up and out of the data collector.
  3. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: 手順 3、 1の画像 1
    • Remove any card that may be in the slots under the top cover you removed.
  4. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: 手順 4、 1の画像 1
    • Using a T6 torx driver, remove the 8 torx screws and then lift the back cover off. There is a rubber gasket between the front and back of the case. Make note of how it fits in for when you reassemble.
  5. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: 手順 5、 3の画像 1 TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: 手順 5、 3の画像 2 TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: 手順 5、 3の画像 3
    • Flip up the connector using a spudger and gently pull the ribbon cable out. This is the display assembly connector. Next we will gently pull the power cable up using a spudger or pry tool. The area marks by the yellow rectangle comes into play in the next step. This is where the keypad connects to the motherboard.
  6. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: 手順 6、 1の画像 1
    • Now we can remove the motherboard. Simply remove the 11 screws using a T6 torx driver. The motherboard must be lifted straight up. The keypad is connected from underneath the motherboard. It will unplug as you lift the board. That is what you want to happen
終わりに
作成者
4人の作成者と共同で作成されました。
Karl
メンバー登録日: 09/19/14
111 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 34
今までの合計 1,062
