メインコンテンツにスキップ
TDK Life on Record Trek Max A34 Large Speaker Replacement
必要な工具と部品
  1. TDK Life on Record Trek Max A34 Large Speaker Replacement, Large Speaker: 手順 1、 2の画像 1 TDK Life on Record Trek Max A34 Large Speaker Replacement, Large Speaker: 手順 1、 2の画像 2
    • Turn over the device so the bottom is facing up. Remove the screws of the battery cover using the iFixit TR7 screwdriver.
    • Remove the battery cover by pulling up where the screws should go.
  2. TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 2、 2の画像 1 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 2、 2の画像 2
    • Carefully unplug and remove the battery.
    • Use the metal spudger to pry off the rubber bumpers from the bottom of the speaker.
  3. TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 3、 3の画像 1 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 3、 3の画像 2 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 3、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the screws that were underneath the rubber bumpers.
    • Remove the battery holder. Be sure to thread the exposed wires through the hole within the holder.
  4. TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 4、 3の画像 1 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 4、 3の画像 2 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 4、 3の画像 3
    • Use a metal spudger to pry off the front and back mesh screens.
    • You may need to move the metal spudger along the edge of the screen to remove it more easily.
  5. TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 5、 3の画像 1 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 5、 3の画像 2 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 5、 3の画像 3
    • Turn the speaker back upright. Use the metal spudger to pry up the rubber cover to reveal the buttons underneath.
  6. TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 6、 2の画像 1 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 6、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the screws that hold the top cover in place.
    • Remove the top cover.
  7. TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 7、 2の画像 1 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 7、 2の画像 2
    • On the backside of the device, remove the screws using the Phillips #0 screwdriver.
    • Only the screws on the backside are needed to hold the frame together. Do not remove screws on the front.
    • Once the screws are removed, separate the two frame pieces.
  8. TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 8、 1の画像 1
    • Within the device, there is a single cable connecting the large speaker to the motherboard. Unplug this cable.
  9. TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 9、 2の画像 1 TDK Life on Record Trek Max A34 Large Speaker Replacement: 手順 9、 2の画像 2
    • On the front of the device, use the Phillips #0 screwdriver to remove the four screws holding the speaker in.
    • Once the screws are removed, you are able to push the speaker out from behind.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Mario Lazaga
メンバー登録日: 01/14/19
1 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S3-G3, Wilson Spring 2019 IUPUI, Team S3-G3, Wilson Spring 2019人のメンバー
IUPUI-WILSON-S19S3G3
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 690
