メインコンテンツにスキップ
TDK Life on Record A26 Battery Replacement
必要な工具と部品
  1. TDK Life on Record A26 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Get a replacement battery from the TDK company. The battery part number is E23-00059-01.
  2. TDK Life on Record A26 Battery Replacement: 手順 2、 2の画像 1 TDK Life on Record A26 Battery Replacement: 手順 2、 2の画像 2
    • Obtain the screwdriver and the T09 (Torx) bit from the iFixit toolkit and assemble them together.
  3. TDK Life on Record A26 Battery Replacement: 手順 3、 2の画像 1 TDK Life on Record A26 Battery Replacement: 手順 3、 2の画像 2
    • Use the T09-bit screwdriver to remove the two 8-mm torx screws on the bottom strip of the speaker.
  4. TDK Life on Record A26 Battery Replacement: 手順 4、 3の画像 1 TDK Life on Record A26 Battery Replacement: 手順 4、 3の画像 2 TDK Life on Record A26 Battery Replacement: 手順 4、 3の画像 3
    • Remove the faceplate by using the pointy side of the black plastic spudger.
    • Stick the point of the spudger into one of the corners surrounding the faceplate and gently pull it up.
  5. TDK Life on Record A26 Battery Replacement: 手順 5、 1の画像 1
    • Then exchange the T09 bit for a PH1 bit
  6. TDK Life on Record A26 Battery Replacement: 手順 6、 2の画像 1 TDK Life on Record A26 Battery Replacement: 手順 6、 2の画像 2
    • Use the PH1-bit screwdriver to remove the eight 11-mm Phillips head screws that are located behind the faceplate.
  7. TDK Life on Record A26 Battery Replacement: 手順 7、 2の画像 1 TDK Life on Record A26 Battery Replacement: 手順 7、 2の画像 2
    • Remove the one 7-mm Phillips head screw located on the lower left of the front of the speaker with the PH1-bit screwdriver.
  8. TDK Life on Record A26 Battery Replacement: 手順 8、 2の画像 1 TDK Life on Record A26 Battery Replacement: 手順 8、 2の画像 2
    • After all screws are removed, turn the speaker over to the back of the speaker.
  9. TDK Life on Record A26 Battery Replacement: 手順 9、 3の画像 1 TDK Life on Record A26 Battery Replacement: 手順 9、 3の画像 2 TDK Life on Record A26 Battery Replacement: 手順 9、 3の画像 3
    • Use the blue plastic opening tool from the toolkit to pry off the back of the speaker, gradually moving around the device.
    • Make sure to open it evenly on all sides.
  10. TDK Life on Record A26 Battery Replacement: 手順 10、 2の画像 1 TDK Life on Record A26 Battery Replacement: 手順 10、 2の画像 2
    • Then remove the bottom narrow strip of plastic to uncover the battery.
  11. TDK Life on Record A26 Battery Replacement: 手順 11、 2の画像 1 TDK Life on Record A26 Battery Replacement: 手順 11、 2の画像 2
    • Follow the red, black, and white wires attached to the green battery sleeve down to the white small plug.
  12. TDK Life on Record A26 Battery Replacement: 手順 12、 2の画像 1 TDK Life on Record A26 Battery Replacement: 手順 12、 2の画像 2
    • Once you have found the white plug, gently grip the colored wires and carefully pull to remove the white plug from the speaker.
終わりに
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Elise Howard
メンバー登録日: 10/13/15
831 ポイント
3のガイドは作成済み
チーム
Sam Houston State, Team 2-2, Blackburne Fall 2015 Sam Houston State, Team 2-2, Blackburne Fall 2015人のメンバー
SHSU-BLACKBURNE-F15S2G2
3 メンバー
3のガイドは作成済み
2 件のコメント
This procedure is totally unnecessary! TDK has much simpler instructions. http://downloads.imationsupport.com/lor/...
Marty F - 返信
Actually, this page DID help me as the other “simpler” instrucions didn’t work, as I was unable to slide the battery cover after removing the two screws.In any case the entire procedure only took about ten minutes, so THANK YOU!
Sander - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 25
今までの合計 6,958
