メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TCL 30Z Screen Protector Replacement
必要な工具と部品
  1. TCL 30Z Screen Protector Replacement, Prepare Your Workspace: 手順 1、 1の画像 1
    • Begin by turning off your TCL 30Z and finding a clean, well-lit workspace. Gather all necessary tools and materials.
    FixBotに聞いてみる
  2. TCL 30Z Screen Protector Replacement, Remove the Old Screen Protector: 手順 2、 1の画像 1
    • Use a plastic pry tool to gently lift one corner of the existing screen protector. Gradually peel it off, applying slight pressure to release any adhesive. Note: Be careful not to damage the screen or any surrounding components during this process.
    FixBotに聞いてみる
  3. TCL 30Z Screen Protector Replacement, Clean the Screen: 手順 3、 1の画像 1
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    • Wipe the screen with a microfiber cloth to remove any smudges or fingerprints. Use cleaning solution or isopropyl alcohol for stubborn stains. Ensure the screen is completely dry before proceeding.
    • Reminder: Take your time during this step to ensure a clean surface for the new screen protector.
    FixBotに聞いてみる
  4. TCL 30Z Screen Protector Replacement, Align the Replacement Screen Protector: 手順 4、 1の画像 1
    • Carefully align the new screen protector with the edges of the screen. Once aligned, use your fingers to gently press it onto the screen.
    • Caution: Avoid touching the adhesive side of the screen protector to prevent fingerprints or debris.
    FixBotに聞いてみる
  5. TCL 30Z Screen Protector Replacement, Smooth out Bubbles: 手順 5、 1の画像 1
    • If any air bubbles are present, use a plastic pry tool or your fingers to smooth them toward the edges. Work from the center to ensure a bubble-free application.
    • Note: Small bubbles may disappear over time, but larger ones may need additional attention.
    FixBotに聞いてみる
  6. TCL 30Z Screen Protector Replacement, Final Inspection: 手順 6、 1の画像 1
    • Inspect the screen for any remaining bubbles or dust particles. If necessary, use dust removal stickers to lift and remove particles. Ensure the screen protector is securely in place.
    • Reminder: Allow the device to rest undisturbed for a few hours to ensure optimal adhesion.
    FixBotに聞いてみる
終わりに
To replace the screen protector of TCL 30Z, follow these instructions in their order.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Timothy
メンバー登録日: 11/15/23
160 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 26
今までの合計 361
