メインコンテンツにスキップ
TCA Yoke Calibration
    • If you have your Yoke plugged-in, then unplug it.
    • Set the switch at the back of the Yoke to PC position.
    • If you are using Xbox, you still need to set the switch to PC position.
    • Don't forget to switch it back to Xbox, once you have completed this guide.
    • Make sure that Roll and Pitch are at resting point.
    • Make sure the right mini-stick is at resting point.
    • Make sure that Throttles are in the middle
    • Throttles don't have to be in the exact middle.
  1. TCA Yoke Calibration, Press and hold the indicated buttons: 手順 4、 1の画像 1
    • Press and hold the buttons highlighted in the image
    • Connect the Yoke to USB port while holding the buttons.
    • Once the Xbox button starts flashing, release the buttons.
  2. TCA Yoke Calibration, Press XBOX button: 手順 6、 1の画像 1
    • Press on the Xbox button.
    • It should start flashing faster.
  3. TCA Yoke Calibration, Move the Yoke all the way to the right.: 手順 7、 1の画像 1
    • Move the Yoke to the right, until you reach maximum.
    • Return the Yoke to Center.
    • For better results, move it smoothly, without forcing.
  4. TCA Yoke Calibration, Move the Yoke all the way to the left.: 手順 8、 1の画像 1
    • Move the Yoke to the left, until you reach maximum.
  5. TCA Yoke Calibration, Push the Yoke forward: 手順 9、 1の画像 1
    • Push the Yoke forward, until you reach maximum.
    • Make sure to not accidentally move yoke Left or Right.
  6. TCA Yoke Calibration, Pull the Yoke backwards: 手順 10、 1の画像 1
    • Pull the Yoke towards yourself, until you reach maximum.
  7. TCA Yoke Calibration, Move the mini-stick to the right: 手順 11、 1の画像 1
    • Move the mini-stick to the right, until you reach maximum.
    • Return the mini-stick to Center.
  8. TCA Yoke Calibration, Move the mini-stick to the left.: 手順 12、 1の画像 1
    • Move the mini-stick to the left, until you reach maximum.
  9. TCA Yoke Calibration, Move the mini-stick up: 手順 13、 1の画像 1
    • Move the mini-stick up, until you reach maximum.
  10. TCA Yoke Calibration, Move mini-stick down: 手順 14、 1の画像 1
    • Move the mini-stick down, until you reach maximum.
  11. TCA Yoke Calibration, Move both Throttles down: 手順 15、 1の画像 1
    • Move both throttles down, until you reach maximum.
  12. TCA Yoke Calibration, Move throttles up: 手順 16、 1の画像 1
    • Move both throttles up, until you reach maximum.
  13. TCA Yoke Calibration, Press XBOX button: 手順 17、 1の画像 1
    • Press Xbox button to finish the calibration.
    • Xbox button should stop flashing.
    • Make sure that Yoke, Throttles and mini-sticks have been returned to neutral positions.
ゴール
作成者
1人の作成者と共同作成されました。
Formica Fusca
メンバー登録日: 08/01/24
2,595 ポイント
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 74
今までの合計 917
