はじめに
This guide is useful if the SIM card of the phone needs to be replaced or removed.
ツール
工具は必要ありません。
パーツ
パーツは必要ありません。
  1. To remove the battery cover, first turn the phone so that the keypad is face down. While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover. Slide the battery cover toward the bottom of the phone to remove.
    • To remove the battery cover, first turn the phone so that the keypad is face down.
    • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
    • Slide the battery cover toward the bottom of the phone to remove.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. To remove the battery, first grab it using a finger on either side. Pull the battery upward, while securing the phone with your other hand.
    • To remove the battery, first grab it using a finger on either side.
    • Pull the battery upward, while securing the phone with your other hand.
    • Gently remove the battery and place it to the side of the phone.
  4. Open the SIM card door, located on the lower right part of the phone. Insert the SIM card into the door with the gold plating facing downward. Close the SIM card door by lightly pushing downward.
    • Open the SIM card door, located on the lower right part of the phone.
    • Insert the SIM card into the door with the gold plating facing downward.
    • Close the SIM card door by lightly pushing downward.
まとめ
Kaitlyn Patterson
メンバー登録日: 2012年10月22日
45 ポイント
3のガイドは作成済み
チーム
Clemson, Team 15-4, Benson Fall 2012 Clemson, Team 15-4, Benson Fall 2012人のメンバー
CLEM-BENSON-F12S15G4
4 メンバー
10のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 308
