メインコンテンツにスキップ
T-Mobile Huawei Prism U8651T LCD Replacement
必要な工具と部品
  1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: 手順 1、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: 手順 1、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: 手順 1、 3の画像 3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: 手順 2、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: 手順 2、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: 手順 2、 3の画像 3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: 手順 3、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: 手順 3、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: 手順 3、 3の画像 3
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: 手順 4、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: 手順 4、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: 手順 4、 3の画像 3
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: 手順 5、 2の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: 手順 5、 2の画像 2
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: 手順 6、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: 手順 6、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: 手順 6、 3の画像 3
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: 手順 7、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: 手順 7、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: 手順 7、 3の画像 3
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: 手順 8、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: 手順 8、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: 手順 8、 3の画像 3
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: 手順 9、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: 手順 9、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: 手順 9、 3の画像 3
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: 手順 10、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: 手順 10、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: 手順 10、 3の画像 3
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: 手順 11、 3の画像 1 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: 手順 11、 3の画像 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: 手順 11、 3の画像 3
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Dillon
メンバー登録日: 10/23/14
578 ポイント
5のガイドは作成済み
チーム
Michigan Tech, Team 1-7, Lauer Fall 2014 Michigan Tech, Team 1-7, Lauer Fall 2014人のメンバー
MTU-LAUER-F14S1G7
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 998
