メインコンテンツにスキップ
Swann Doorphone Video Intercom Camera Replacement
必要な工具と部品
  1. Swann Doorphone Video Intercom Camera Replacement, Camera: 手順 1、 3の画像 1 Swann Doorphone Video Intercom Camera Replacement, Camera: 手順 1、 3の画像 2 Swann Doorphone Video Intercom Camera Replacement, Camera: 手順 1、 3の画像 3
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  2. Swann Doorphone Video Intercom Camera Replacement: 手順 2、 2の画像 1 Swann Doorphone Video Intercom Camera Replacement: 手順 2、 2の画像 2
    • With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
  3. Swann Doorphone Video Intercom Camera Replacement: 手順 3、 3の画像 1 Swann Doorphone Video Intercom Camera Replacement: 手順 3、 3の画像 2 Swann Doorphone Video Intercom Camera Replacement: 手順 3、 3の画像 3
    • Remove the other wires using the same steps as the blue wire.
    • Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
    • Remove the back plate by pulling the plate away from the device.
  4. Swann Doorphone Video Intercom Camera Replacement: 手順 4、 2の画像 1 Swann Doorphone Video Intercom Camera Replacement: 手順 4、 2の画像 2
    • Using the JIS #0 screwdriver, remove the 1mm screws from behind the camera.
  5. Swann Doorphone Video Intercom Camera Replacement: 手順 5、 2の画像 1 Swann Doorphone Video Intercom Camera Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
    • Pull slowly in the direction of the cables until the connector is no longer attached.
  6. Swann Doorphone Video Intercom Camera Replacement: 手順 6、 2の画像 1 Swann Doorphone Video Intercom Camera Replacement: 手順 6、 2の画像 2
    • Remove the camera from the device.
終わりに
作成者
4人の作成者と共同で作成されました。
Emily Stenke
メンバー登録日: 02/14/18
555 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S2-G4, Eyestone Spring 2018 USF Tampa, Team S2-G4, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S2G4
4 メンバー
5のガイドは作成済み
15 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 696
