メインコンテンツにスキップ
SwagTron T1 Outer Shell Replacement
必要な工具と部品
  1. SwagTron T1 Outer Shell Replacement, Back Panels: 手順 1、 1の画像 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Outer Shell Replacement: 手順 2、 3の画像 1 SwagTron T1 Outer Shell Replacement: 手順 2、 3の画像 2 SwagTron T1 Outer Shell Replacement: 手順 2、 3の画像 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Outer Shell Replacement: 手順 3、 3の画像 1 SwagTron T1 Outer Shell Replacement: 手順 3、 3の画像 2 SwagTron T1 Outer Shell Replacement: 手順 3、 3の画像 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Outer Shell Replacement, Outer Shell: 手順 4、 2の画像 1 SwagTron T1 Outer Shell Replacement, Outer Shell: 手順 4、 2の画像 2
    • Unscrew the twelve 10mm screws that connect the metal chassis to the top plastic panel.
    • These screws will be low into the SwagTron.
  5. SwagTron T1 Outer Shell Replacement: 手順 5、 1の画像 1
    • Turn the SwagTron right side up and slightly lift up the panel.
    • Be careful to not pull too hard because the panel is still attached to the SwagTron by wires.
  6. SwagTron T1 Outer Shell Replacement: 手順 6、 3の画像 1 SwagTron T1 Outer Shell Replacement: 手順 6、 3の画像 2 SwagTron T1 Outer Shell Replacement: 手順 6、 3の画像 3
    • Turn the SwagTron over and disconnect the wires from the motherboard.
    • Follow the wires to the underside of the SwagTron.
    • Carefully remove the cord and the panel together.
    • All the panels are now free from the SwagTron.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Gloria Whang
メンバー登録日: 04/13/17
179 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G5
4 メンバー
5のガイドは作成済み
4 件のコメント
Where did you ind a replacement shell for the Swagtron T1? I need to buy a new one, but can’t seem to find a place to buy it online.
Syd Jensen - 返信
Where can I buy a Swagtron T1 replacement shell?
Syd Jensen - 返信
Syd any luck finding a replacement shell?  I need to order the same kind and cannot find it online.
Craig -
Amazon.com Keyword: CertiCable
Jesse Griffis -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 1,938
