メインコンテンツにスキップ
SwagTron T1 Gyroscope Replacement
必要な工具と部品
  1. SwagTron T1 Gyroscope Replacement, Back Panels: 手順 1、 1の画像 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Gyroscope Replacement: 手順 2、 3の画像 1 SwagTron T1 Gyroscope Replacement: 手順 2、 3の画像 2 SwagTron T1 Gyroscope Replacement: 手順 2、 3の画像 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
    The panels don’t come off after removing the screws. Could they be also glued in place?
    uygar_selman - 返信
    Same issue here with the T882. Resorted to trying to pry the shell off but haven’t been able to yet. The closer I get to the center, the harder it is.
    Victoria Milhoan - 返信
    FYI - there are stickers over two of the screws (one on each side). Once the stickers are removed, and the screws taken out, the shell came off easily.
    THANK YOU! The screws were under the stickers near the center.
    Liz Vance -
    I removed all the screws from the panel, and I am pulling and tugging and I can only get one side loose but not the other. Anyone else experience this?
    MS R - 返信
  3. SwagTron T1 Gyroscope Replacement: 手順 3、 3の画像 1 SwagTron T1 Gyroscope Replacement: 手順 3、 3の画像 2 SwagTron T1 Gyroscope Replacement: 手順 3、 3の画像 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
    Where can I buy the shell
    Julio Barahona - 返信
    Where can I buy the battery?
    Daniel O'Brien - 返信
  4. SwagTron T1 Gyroscope Replacement, Gyroscope: 手順 4、 2の画像 1 SwagTron T1 Gyroscope Replacement, Gyroscope: 手順 4、 2の画像 2
    • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
  5. SwagTron T1 Gyroscope Replacement: 手順 5、 1の画像 1
    • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
  6. SwagTron T1 Gyroscope Replacement: 手順 6、 3の画像 1 SwagTron T1 Gyroscope Replacement: 手順 6、 3の画像 2 SwagTron T1 Gyroscope Replacement: 手順 6、 3の画像 3
    • Carefully remove the gyroscope component from the SwagTron.
終わりに
9 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Teagan Allen
メンバー登録日: 04/18/17
426 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G5
4 メンバー
5のガイドは作成済み
5 件のコメント
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - 返信
Amazon.com Keyword: CertiCable
Jesse Griffis -
Where do you get the replacement?
Brittany Conner - 返信
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - 返信
I just got mine today and after the first hour I ran into a shoe and then I tried recalibrating it but it was no use. If someone knows what’s going on please tell me! Thank you :)
Elia Leon - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 50
今までの合計 7,244
