メインコンテンツにスキップ
SwagTron T1 Battery Replacement
必要な工具と部品
  1. SwagTron T1 Battery Replacement, Back Panels: 手順 1、 1の画像 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Battery Replacement: 手順 2、 3の画像 1 SwagTron T1 Battery Replacement: 手順 2、 3の画像 2 SwagTron T1 Battery Replacement: 手順 2、 3の画像 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
    The panels don’t come off after removing the screws. Could they be also glued in place?
    uygar_selman - 返信
    Same issue here with the T882. Resorted to trying to pry the shell off but haven’t been able to yet. The closer I get to the center, the harder it is.
    Victoria Milhoan - 返信
    FYI - there are stickers over two of the screws (one on each side). Once the stickers are removed, and the screws taken out, the shell came off easily.
    THANK YOU! The screws were under the stickers near the center.
    Liz Vance -
    I removed all the screws from the panel, and I am pulling and tugging and I can only get one side loose but not the other. Anyone else experience this?
    MS R - 返信
  3. SwagTron T1 Battery Replacement: 手順 3、 3の画像 1 SwagTron T1 Battery Replacement: 手順 3、 3の画像 2 SwagTron T1 Battery Replacement: 手順 3、 3の画像 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
    Where can I buy the shell
    Julio Barahona - 返信
    Where can I buy the battery?
    Daniel O'Brien - 返信
  4. SwagTron T1 Battery Replacement, Battery: 手順 4、 1の画像 1
    • Your SwagTron should look like this once the back panels are removed.
    • The battery is located on the left side as shown.
    Mine does not look like this.
    John Whisenant - 返信
  5. SwagTron T1 Battery Replacement: 手順 5、 2の画像 1 SwagTron T1 Battery Replacement: 手順 5、 2の画像 2
    • Unscrew the four 10mm screws that secure the battery using a Philips #2 screwdriver.
    • The screws may be tightly in place. If so, use some effort to unscrew them.
    • The battery is still connected to two wires that go to the motherboard.
    Can anybody tell me please where I can find a replacement battery?
    Daniel O'Brien - 返信
  6. SwagTron T1 Battery Replacement: 手順 6、 3の画像 1 SwagTron T1 Battery Replacement: 手順 6、 3の画像 2 SwagTron T1 Battery Replacement: 手順 6、 3の画像 3
    • Disconnect the two wires that come from the battery from the wires coming from the hoverboard.
    • There are only two connections that need to be separated.
    • The battery should be completely removed from the hoverboard.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Adrian Abarca
メンバー登録日: 04/18/17
360 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G5
4 メンバー
5のガイドは作成済み
13 件のコメント
Is there a blue and black wire that gets connected also?
Where dI you get the battery.
Thanks.
Paul Bromberg - 返信
I’m also wanting to know where you found the replacement battery. I’ve found several replacement battery packs for hover boards but none that match the T1. The T1 has a circuit board attached to the battery pack, fused…. where can I find this?
Daniel O'Brien - 返信
Yep, can’t find a T1 battery anywhere. Even Swagtron won’t tell me how to get one, short of sending it in for service.
renystro - 返信
Swagtron tech support offers to replace any battery if under warranty, which requires that you pay to ship the entire unit back to them for service. This seems insanely costly, but probably avoids voiding the warranty.
If you are out-of-warranty, they said they would sell me a battery, but did not offer any pricing info.
If you want to do-it-yourself, out-of-warranty: My guess it that the metal shielded “battery” actually contains commercially available LiIon cells which can be privately sourced, but may require some wire splicing, may be a shock hazard and such, so is more complex than just plug-in a replacement.
Chris Gray - 返信
What type of replacement battery is used for the Swagtron T1?
Swagtron wont give me the information!!
Maria Taylor - 返信
Did anyone ever find out how to buy the battery for the swagtron T1?
Charles Phippen -
So every couple of months I notice my daughters T1 sitting… dead…. in our garage and I think to myself: “Maybe now it’s possible to find a replacement battery for this fairly expensive gift that she enjoyed… after all… it’s a battery… you should be able to replace a BATTERY.”
Sadly every time I am less surprised but more annoyed to see that I cannot. In hind sight I should have known a company that picked such a stupid name at Swagatron would suck.
Thanks for nothing.
Daniel O'Brien - 返信
I too can’t find where to purchase a battery to replace this junk product that didn’t hold a charge long at all. They said I could send it in for $20, pay like $60 for service and another $20ish to replace the battery. In a chat I was told it takes a 12Volt -3.0AH lead acid battery, which doesn’t really help me much I don’t think. If anyone knows of a battery that works as a replacement, please share.
Paul - 返信
I have a T6. Same battery specs, same lack of info or help from Swagtron, and there doesn’t seem to be any useful reply here, so now we know how to take out a bad battery and put it back in. Seems we’re SOL.
LastBut NotLeast - 返信
I have a T6, but the battery model number is the same as what is shown here. Anyone found a suitable replacement yet? I really don’t want to pay to have to ship this unit back to Swagtron just for a battery replacement
Jeffrey - 返信
For replacement battery go to swagtron.com/returns and use the chat feature. You’ll have to provide them a picture of your battery so they can pull the specs and order the correct replacement. $59.99 for battery (haven’t seen shipping cost yet). They will order, then send you an invoice, you pay using the link in the invoice, and then they ship within 3-5 business days.
Jerry Larkin - 返信
Any guide available on how to open Swag T8?
sandeep vyas - 返信
Can you post a link where we can get a replacement battery and a charger for this T1 Swag Board?
Cat Forbes - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 27
過去 30 日: 109
今までの合計 13,443
