メインコンテンツにスキップ
Sungale Cyberus ID707WTA Screen Replacement
必要な工具と部品
  1. Sungale Cyberus ID707WTA Screen Replacement, Battery: 手順 1、 1の画像 1
    • Press firmly on lower portion of the back cover and slide the cover towards the bottom to remove cover.
  2. Sungale Cyberus ID707WTA Screen Replacement: 手順 2、 1の画像 1
    • Pull on the plug carefully until it releases from the port and simply pull the battery out after.
  3. Sungale Cyberus ID707WTA Screen Replacement, Screen: 手順 3、 1の画像 1
    • Unscrew the six 6.01mm Phillips one screws that hold the casing together.
  4. Sungale Cyberus ID707WTA Screen Replacement: 手順 4、 2の画像 1 Sungale Cyberus ID707WTA Screen Replacement: 手順 4、 2の画像 2
    • Pry open the casing with a plastic opening tool. You will want to use a thin blue plastic opening tool to get in between the creases of the casing.
  5. Sungale Cyberus ID707WTA Screen Replacement: 手順 5、 1の画像 1
    • Unscrew the five 4.47mm Phillips one screws that must be taken out to detach the motherboard from the casing.
  6. Sungale Cyberus ID707WTA Screen Replacement: 手順 6、 1の画像 1
    • Detach the motherboard from the screen by taking out the input on the left marked in red as well as carefully detaching the ribbon from the screen which is also marked in red in the middle.
  7. Sungale Cyberus ID707WTA Screen Replacement: 手順 7、 1の画像 1
    • Separate the touch screen (the grey and white specs) from the metal casing it is enclosed in by bending the casing outward.
    • Again this can be done with the plastic opening tool. You will want to do this around the entire casing before trying to pry it out which is the next step.
    • This is the most tedious and time consuming step.
  8. Sungale Cyberus ID707WTA Screen Replacement: 手順 8、 2の画像 1 Sungale Cyberus ID707WTA Screen Replacement: 手順 8、 2の画像 2
    • Pry the screen open with the blue plastic opening tools while using another plastic opening tool as a jack to remain in place while you pry around the entire screen.
  9. Sungale Cyberus ID707WTA Screen Replacement: 手順 9、 1の画像 1
    • Lift the screen away from the case. Be careful, the screen shown lifted here is actually put together in multiple layers so you'll want to be careful not to separate them.
終わりに
作成者
3人の作成者と共同で作成されました。
Austin_Parkes
メンバー登録日: 03/21/18
337 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S4-G4, Baechle Spring 2018 IUPUI, Team S4-G4, Baechle Spring 2018人のメンバー
IUPUI-BAECHLE-S18S4G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 130
