はじめに
In case of speaker malfunction,here is all steps needed to replace this part in your Sungale CyberUs.
必要な工具と部品
Hold the device so the left side is facing towards you (like in the picture shown) so the two 4mm PH001 screws are exposed and easier to access.
Now, carefully we will remove the battery. Find the leads, or the red and black wires going to the battery from the motherboard. To free the wires you must cut the wire near the battery leads. Make sure both ends are clean and have enough exposed wire.
ある他の人がこのガイドを完成しました。
