メインコンテンツにスキップ
Sungale CyberUs Battery Replacement
必要な工具と部品
  1. Sungale CyberUs Battery Replacement, Screen: 手順 1、 1の画像 1
    • Make sure to have the device turned off to prevent any minor electric shock.
    • Hold the device so the left side is facing towards you (like in the picture shown) so the two 4mm PH001 screws are exposed and easier to access.
  2. Sungale CyberUs Battery Replacement: 手順 2、 1の画像 1
    • Remove both 4mm PH001 screws from the side panel.
  3. Sungale CyberUs Battery Replacement: 手順 3、 2の画像 1 Sungale CyberUs Battery Replacement: 手順 3、 2の画像 2
    • Carefully pry up one of the top corners of the screen with a plastic spudger (prying tool). Slide the tool along the edges to release it from the housing.
    • The screen may make some cracking noises as you pry it from the casing. This is expected.
    • The screen is still connected to the motherboard. Use force with caution.
  4. Sungale CyberUs Battery Replacement: 手順 4、 1の画像 1
    • Gently turn screen over, to the side, to reveal the ZIF connector attached to the motherboard.
  5. Sungale CyberUs Battery Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    購入する
    • Gently using tweezers, flip the black clip up. Pull the ZIF connector out.
    • You screen is still not completely detached from the device.
  6. Sungale CyberUs Battery Replacement: 手順 6、 2の画像 1 Sungale CyberUs Battery Replacement: 手順 6、 2の画像 2
    • Using the prying tool, slide the black clip out. Pull the ZIF connector out and to the left, the screen is now detached from the motherboard.
  7. Sungale CyberUs Battery Replacement, Battery: 手順 7、 1の画像 1
    • Now, carefully we will remove the battery. Find the leads, or the red and black wires going to the battery from the motherboard. To free the wires you must cut the wire near the battery leads. Make sure both ends are clean and have enough exposed wire.
  8. Sungale CyberUs Battery Replacement: 手順 8、 1の画像 1
    • You will have to clean the connections and solder the new battery back into place. Just as before, you want to reconnect the new battery to the motherboard.
終わりに
作成者
4人の作成者と共同で作成されました。
Grayson Heinbaugh
メンバー登録日: 10/03/16
158 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 1-4, Harley Fall 2016 IUPUI, Team 1-4, Harley Fall 2016人のメンバー
IUPUI-HARLEY-F16S1G4
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 8
今までの合計 164
