メインコンテンツにスキップ
Sun King Solo Solar Lantern Battery Replacement
必要な工具と部品
  1. Sun King Solo Solar Lantern Battery Replacement, Locate and Remove the Screws: 手順 1、 1の画像 1
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Battery Replacement, Separate the Device: 手順 2、 1の画像 1
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: 手順 3、 2の画像 1 Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: 手順 3、 2の画像 2
    • Locate the battery.
    • Gently lift the battery from the device.
  4. Sun King Solo Solar Lantern Battery Replacement, Remove the Battery: 手順 4、 1の画像 1
    • Locate the clip attaching the battery pack to the circuit board.
    • Use tweezers to remove the portion of the clip attached to the battery.
    • Do not pull directly on the wires! They can easily be damaged.
  5. Sun King Solo Solar Lantern Battery Replacement, Replace the Battery: 手順 5、 1の画像 1
    • Align the black wire of the new battery towards the center of the device.
    • Press down firmly on the clip to insure that it is properly connected.
    • Properly dispose of the Lithium-Ion Battery. Lithium Battery Disposal
  6. Sun King Solo Solar Lantern Battery Replacement, Reseat the Battery: 手順 6、 1の画像 1
    • Seat the battery in the orange component so that the short end of the battery pack is touching the foam bumper.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Anna
メンバー登録日: 10/23/14
595 ポイント
4のガイドは作成済み
チーム
Michigan Tech, Team 1-3, Lauer Fall 2014 Michigan Tech, Team 1-3, Lauer Fall 2014人のメンバー
MTU-LAUER-F14S1G3
3 メンバー
5のガイドは作成済み
8 件のコメント
please help in finding the life p04 battery,3.2v ,1500 mah,batch #20309
SHARATH PONUGOTI - 返信
as my solar lights battery is dead..iam unable to find out whr i will get a new one
where to get the battery spare part?
johnkoisasi - 返信
Please help me in finding PRO sunking battery 6.6v,1450mAh, Batch 30130.
Please contact me:stanleymayor944@yahoo.com
Stanley - 返信
Howi can get 6.6 v sunking pro battery?please help me.
kapildeo mandal - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 32
今までの合計 3,919
