メインコンテンツにスキップ
Stratitec S5202A Snap-in Circuit Breaker Replacement
必要な工具と部品
  1. Stratitec S5202A Snap-in Circuit Breaker Replacement, Snap-in Circuit Breaker: 手順 1、 1の画像 1
    • Place the power strip on a level surface with the bottom facing up.
  2. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 2、 1の画像 1
    • Remove the nine screws from the bottom plate using an IfixIt bit driver and the bit labeled PH1.
  3. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 3、 1の画像 1
    • Remove the lower plate to expose the internal components.
  4. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 4、 2の画像 1 Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 4、 2の画像 2
    • The soldering tools will be hot, as will the solder when melted. Avoid contact with skin.
    • Solder fumes are toxic, avoid inhaling.
    • Turn on the solder station to the highest temperature setting and wait for it to heat.
    • Each solder station is different and some many only have an on/off switch with no temperature setting.
    • It may take up to ten minutes for the solder station to heat completely.
    • The easiest way to be sure the solder iron is hot enough is to touch the solder to the iron and see if it melts.
  5. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 5、 2の画像 1 Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 5、 2の画像 2
    • Locate the power switch leads and apply solder iron tip to wire 1.
    • Waiting for the solder to completely melt may take up to a minute or two.
    • Do not pull on the wire until the solder on both the lead and the wire is completely melted.
  6. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 6、 1の画像 1
    • Once the solder has melted on the switch, use a pair of flat-head pliers to remove the wire.
    • In some cases it may be necessary to cut the tips of the wire off in order to free the wire.
  7. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 7、 1の画像 1
    • Repeat steps 5 and 6 for wire two.
  8. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 8、 1の画像 1
    • Loosen the power switch by pushing on the plastic side tabs located inside the power strip case.
    • If you can't get the tabs to release, use a pair of flat-heat pliers and push down on one tab at a time.
    • There are two tabs on each side of the switch.
  9. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 9、 2の画像 1 Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 9、 2の画像 2
    • Carefully remove the unsoldered power switch component.
  10. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 10、 3の画像 1 Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 10、 3の画像 2 Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 10、 3の画像 3
    • Replace the old switch component with the new SS-001.
    • Snap in the circuit breaker component by pushing the switch down until the tabs lock into place.
    • You should be able to hear the tabs snap into place.
  11. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 11、 1の画像 1
    • Apply new solder onto the iron tip.
  12. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 12、 1の画像 1
    • Solder wire 1 onto the power switch tab.
    • If necessary apply extra solder to the metal pin until the wire is connected.
    • If you forget which wire goes to which tab just be sure that your switch orientation is the same as the picture shown. Once you are sure it is in the correct way, the wires simply stay on their respective sides. The left wire goes with the left pin and the right wire goes with the right pin.
  13. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 13、 2の画像 1 Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 13、 2の画像 2
    • Repeat steps 11 and 12 for wire 2.
  14. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 14、 1の画像 1
    • Hold wire down with pliers until solder cools and sets.
    • If needed add more solder to wire/lead connection point.
  15. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 15、 1の画像 1
    • Test power strip using an Ohmmeter by touching both solder joints while in off position.
    • When the switch is in the off position the circuit should be “broken” and in turn show a resistance.
    • Even if the resistance is small like the 2Ωs pictured here, it still means the switch is doing its job.
  16. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 16、 1の画像 1
    • Repeat step 15 with the power switch in the on position.
    • While the switch is in the on position the circuit should be open and there should be no resistance between the two pins.
  17. Stratitec S5202A Snap-in Circuit Breaker Replacement: 手順 17、 1の画像 1
    • Repeat steps 2-3 in reverse order for reassembly.
終わりに
Now that you are finished, you have the satisfaction of repairing something broken as well as cutting down on electronic waste. If there are problems such as: the switch not turning on, no voltage connectivity, or if the Ohmmeter does not give the appropriate readings in steps 15 and 16, you may be lacking the appropriate amount of solder for your wiring. To fix this, reapply the solder to the joints where the wires connect to the circuit breaker. Since surge protectors are a growing need with more electronics being utilized, this guide will help you ensure your surge protector is well maintained and ready to protect your electronics.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
rainbentrott
メンバー登録日: 09/21/15
101 ポイント
1ガイドが承認済み
チーム
Colorado Springs, Team 6-1, Mcmichael Fall 2015 Colorado Springs, Team 6-1, Mcmichael Fall 2015人のメンバー
UCCS-MCMICHAEL-F15S6G1
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 923
