メインコンテンツにスキップ
Stihl O25 Chain Replacement
必要な工具と部品
  1. Stihl O25 Chain Replacement, Stihl O25 Chain: 手順 1、 1の画像 1
    • Be sure to turn off the chainsaw before servicing it.
    • Caution: Chainsaw blades are sharp. Wear protective gloves through the procedure.
    • Loosen the nuts on the chain cover with the wrench side of the scrench until the cover comes off of the saw.
  2. Stihl O25 Chain Replacement: 手順 2、 1の画像 1
    • Pull the chain and chainsaw bar off of the power head.
    • Pull the chain back to loosen off of the gears, and lift straight up.
  3. Stihl O25 Chain Replacement: 手順 3、 1の画像 1
    • Clean out the grooves on the chainsaw bar. This will help with the next step.
  4. Stihl O25 Chain Replacement: 手順 4、 1の画像 1
    • Make sure the chain is positioned correctly. If you are looking at the top of the saw, the chain rotates away from the operator.
    • Position the chain so the teeth face away on the top of the saw.
  5. Stihl O25 Chain Replacement: 手順 5、 1の画像 1
    • Place the bar and chain back onto the saw.
    • The bolt slot on the bar will slide onto the bolts on the saw.
    • The chain will go around the gear towards the back of the saw.
    • You may have to move the chain around to get it to fit properly.
  6. Stihl O25 Chain Replacement: 手順 6、 2の画像 1 Stihl O25 Chain Replacement: 手順 6、 2の画像 2
    • Tighten the chain by turning the tightening screw.
    • Insert the screwdriver end of the scrench into the screw and turn clockwise.
  7. Stihl O25 Chain Replacement: 手順 7、 1の画像 1
    • Chain tightness is often a preference of the chainsaw operator, but a good rule of thumb to follow is when you pull up on the chain, two chain links should come out of the bar grooves.
  8. Stihl O25 Chain Replacement: 手順 8、 1の画像 1
    • Put the cover back on and tighten the nuts down.
  9. Stihl O25 Chain Replacement: 手順 9、 1の画像 1
    • To sharpen the chain, mark one of the teeth with a pencil or sharpie.
  10. Stihl O25 Chain Replacement: 手順 10、 1の画像 1
    • Take a round file and place it on the cutting surface.
  11. Stihl O25 Chain Replacement: 手順 11、 1の画像 1
    • The file should be angled slighty upwards and follow the angle of the saw tooth.
    • Slide the file while applying pressure and twist slightly.
    • Teeth on a saw alternate which way they are facing.
    • Skip one tooth to continue to sharpen on the same side. Use the same number of file strokes on each tooth.
    • Continue to sharpen until you reach the original tooth that was marked. You can then sharpen the set of teeth facing the other way with the same process.
ゴール
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Nathan Comar
メンバー登録日: 03/30/16
182 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team 1-3, Lauer Spring 2016 Michigan Tech, Team 1-3, Lauer Spring 2016人のメンバー
MTU-LAUER-S16S1G3
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 29
今までの合計 1,316
