必要な工具と部品
The air filter is located inside a plastic housing mounted on the left side of the engine.
Lift up the cover locking tab located on the top of the filter housing.
Swing the cover open.
Once it is fully open, lift the cover off the hinges and remove it.
Remove old oil and dirt from the inside of the filter housing with absorbent paper or cloth.
Soak the new air filter with a teaspoon of motor oil.
Position the air filter in the housing.
Swing the cover back up into place. Press firmly on the top edge until the latch seats.
もう少しです!
ゴール
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
Jerry Wheelerさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
