メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Step By Step Guide For Installing a portable AC
  1. Step By Step Guide For Installing a portable AC, Check that everything is there: 手順 1、 1の画像 1
    • The most important place for any homeowner to start when figuring out how to install a portable air conditioner is an inventory. This means going through every item in the box to see what is missing. It also means checking the parts are in working order. Key features include the window slider, hose, screws and the remote.
    • The refrigerant in the unit needs to settle This is a fundamental step, but one that many people may forget. The refrigerant is an essential component for cooling the air in these machines. But, it needs to settle in the right place before it can work. This is achievable by simply standing the device upright for a while.
  2. Step By Step Guide For Installing a portable AC, The hose: 手順 3、 1の画像 1
    • The hose is a vital piece of kit with these portable machines. There should be a series of connectors to hook to the hose. This should create an airtight seal with a little easy rotation into place. Checking that seal for a functional exhaust is essential. The tabs on the connector should then snap onto corresponding tabs on the air conditioner.
    • This exhaust directs the air away from the home and its occupants and out of the house. So, there must be an exit point in the window. The window slider fits on the inside rim, with screws to anchor it in place. Again, this needs a tight seal, which is why the kits have adjustable widths.
    • The air conditioning unit then needs to go in place by the window, so that users can connect the other end of the hose to the window kit. This creates that perfect seal and exhaust system from the machine to the exterior of the property.
    • From there, the only thing left to do to turn on the portable AC machine and make sure everything works. A simple cycle should highlight any faults in the settings, mechanics or seals in the hose. This could take a little time, with a few resets. Once it is over, with no problems, the installation process is complete.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
mariechristine legrand
メンバー登録日: 06/07/18
223 ポイント
1ガイドが承認済み
3件のガイドコメント
With all that being said. I have one question.
How can one add Freon to their portable AC. such as the Haier HPP08XCR. It says it uses R-410A
Curtis Fields - 返信
Actually, I have some idea about this topic. because i have an portable air conditioner in my offiece, and ehrn i need some guideness then ac repair dubai is always ready to help me. they provide 24*7 best service. I share this if anyone need.
jamesmerrin - 返信
My machine is not cooling as I want. What is highest temperature and the lowest temperature to set?
Acquah Bright - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 2,397
