はじめに
If your volume control knob is no longer rotating properly, is damaged or needs cleaning, you may need to remove the knob. Follow this guide to safely access and remove the knob.
必要な工具と部品
Remove the plastic cover using the iFixit opening tool to pry the cover open.
Insert opening picks to keep the cover open as you work your way around the GameDAC.
Pop the cover off.
ある他の人がこのガイドを完成しました。
