メインコンテンツにスキップ
SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement
必要な工具と部品
  1. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: 手順 1、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: 手順 1、 2の画像 2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Circuit Board: 手順 2、 1の画像 1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: 手順 3、 1の画像 1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: 手順 4、 1の画像 1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: 手順 5、 1の画像 1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kyle Chang
メンバー登録日: 01/24/19
1,152 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019人のメンバー
CPSU-WHITE-W19S18G1
4 メンバー
21のガイドは作成済み
3 件のコメント
any idea where i can buy the circuit parts to both side?
erminio santiago - 返信
any idea where i can buy Circuit Board Replacement for both side? please
What's the problem that requires circuit board replacement? My left speaker doesn't work checked and all wires connected. Wondering if the circuit board fixes that
bayarea_rooter - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 17
過去 30 日: 57
今までの合計 9,397
