メインコンテンツにスキップ
Starbucks Barista portafilter disassembly and cleaning
必要な工具と部品
  1. Starbucks Barista portafilter disassembly and cleaning, Starbucks Barista portafilter disassembly and cleaning: 手順 1、 1の画像 1
    • Turn the portafilter handle to the left to remove it from the machine.
    • Flip the portafilter over so the bottom with the 3 screws faces up.
  2. Starbucks Barista portafilter disassembly and cleaning: 手順 2、 2の画像 1 Starbucks Barista portafilter disassembly and cleaning: 手順 2、 2の画像 2
    • Before beginning, make a small, neat "scribe" mark on both the bottom edge of the plastic basket and, right next to it, the top of the metal basket. This match-marks these two pieces. Unscrew and remove the 3 phillips-head screws.
    • Lift off the plastic handle assembly, exposing the internal pressure system and two springs. Take note of the handle's orientation in relation to the metal piece as it will need to be re-attached in exactly the same position to function correctly.
  3. Starbucks Barista portafilter disassembly and cleaning: 手順 3、 2の画像 1 Starbucks Barista portafilter disassembly and cleaning: 手順 3、 2の画像 2
    • Take note of the spring's placement, then carefully remove and set them aside.
    • Clean the pressure assembly with a citrus-based cleaner and a brush, making sure to get under the hinged needle valve. Rinse well, then replace the springs.
    • Reattach the handle assembly with the 3 phillips-head screws. If assembled correctly the handle should pivot slightly in relation to the metal portion, than spring back when released.
終わりに
13 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
David
メンバー登録日: 01/28/11
748 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S4G42
4 メンバー
5のガイドは作成済み
23 件のコメント
Are there any pictures to show how to replace the gasket on the portafilter?
Scott - 返信
any luck on replacing the gasket?
Erica Fisher -
Yeah he needs to add a step 4.
Until he does, take a look at this YT video.
https://www.youtube.com/watch?v=MCf_zOEX...
Gary Naka -
Where can I purchase a portafilter for this? johnbrosnan2010@yahoo.com
johnbrosnan2005 - 返信
i just did this and it worked. my problem was i kept thinking it wasnt working bc the water kept flowing out of the top and not going through the two holes into the cup. I figured out it needs the coffe grounds in there to actually work! thanks!
preceptgirl - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 82
今までの合計 41,309
