はじめに
Is your sharpener not working at all? Does it seem to be "dead"? Then you may need to follow these steps to replace the A/C motor on your Staples 34462 Electric Pencil Sharpener. See our troubleshooting guide for more information on this problem. Note that some soldering may be necessary to complete the steps in this guide. See iFixit's soldering guide for more tips and help on how to best accomplish this step.
  1. Pull out the shavings tray from the pencil sharpener.
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Turn the pencil sharpener on its side.
    • Turn the pencil sharpener on its side.
  3. Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Carefully pull apart the bottom panel from the top panel.
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  7. Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  8. Carefully pull the cover from the top panel and set it aside.
    • Carefully pull the cover from the top panel and set it aside.
  9. Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
    • Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
  10. Carefully pull apart the gear housing's panels.
    • Carefully pull apart the gear housing's panels.
    • The gears are lubricated by petroleum jelly.
  11. Using a Philips 00 screwdriver, remove the first 10.3mm screw attaching the A/C motor to the panel.
    • Using a Philips 00 screwdriver, remove the first 10.3mm screw attaching the A/C motor to the panel.
  12. Gently pry the gear from the panel with a spudger to expose the second screw holding the electric A/C motor to the panel.
    • Gently pry the gear from the panel with a spudger to expose the second screw holding the electric A/C motor to the panel.
    • To ease reassembly, note the orientation of the gear as you pry it free.
  13. Using a Philips 00 screwdriver, remove the second 10.3mm screw securing the electric A/C motor to the panel.
    • Using a Philips 00 screwdriver, remove the second 10.3mm screw securing the electric A/C motor to the panel.
  14. Pull out the electric A/C motor from the gear housing panel.
    • Pull out the electric A/C motor from the gear housing panel.
  15. Using a soldering iron, carefully de-solder the two wires from the electric A/C motor.
    • Using a soldering iron, carefully de-solder the two wires from the electric A/C motor.
    • This step requires soldering. See iFixit's soldering guide for more tips and information.
まとめ
Brian Eliason
メンバー登録日: 2014年10月27日
271 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 1-5, Carnegie Fall 2014 Eastern Washington University, Team 1-5, Carnegie Fall 2014人のメンバー
EWU-CARNEGIE-F14S1G5
7 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 754
