はじめに
If your stapler isn’t stapling, then there’s a good chance the spring is damaged. This guide's purpose is to assist users in replacing the stapler spring.
If you don’t replace the spring yourself, you’ll either have a broken stapler cluttering up your work space or will end up buying a new stapler altogether.
Before using this guide, check to see if the spring itself is damaged. Another possibility of a stapler not working is a staple jam. Be careful when handling the stapler, since it’s possible to staple yourself. We recommend that you empty the staples beforehand.
必要な工具と部品
10 の人々がこのガイドを完成させました。
9 件のコメント
Just what I needed. Thank you! Super clear
Can I replace the black rubber piece that goes on my swingling desk top stapler 70 sheet it came off and my dog chewed it up.
fron this sale ski o donde venden los repuestos de esta engrapadora en Venezuela gran caracas
Romulo -
Wie funktioniert das für große Klammermaschinen wie dieser hier?
Ihr Artikel war sehr leicht zu verstehen und ich habe es geschafft, vielen Dank gacha life!
Where do I obtain a replacement spring for this stapler?
John Drake - 返信
Thank you for this guide, just the ticket!
What size spring is used for yhe pusher and where can it be purchased?
At the top of the guide, click on the link at Parts.
