メインコンテンツにスキップ
Squier Strat Guitar Pickups Replacement
必要な工具と部品
  1. Squier Strat Guitar Pickups Replacement, Pickups: 手順 1、 3の画像 1 Squier Strat Guitar Pickups Replacement, Pickups: 手順 1、 3の画像 2 Squier Strat Guitar Pickups Replacement, Pickups: 手順 1、 3の画像 3
    • Unwind the strings by turning the tuning pegs.
    • Pull the strings out of the tuning peg holes.
    • Push the strings out through the back plate holes.
    • Use a string winder to speed up this process.
  2. Squier Strat Guitar Pickups Replacement: 手順 2、 2の画像 1 Squier Strat Guitar Pickups Replacement: 手順 2、 2の画像 2
    • Remove the 11 screws holding the pickguard to the body of the guitar.
  3. Squier Strat Guitar Pickups Replacement: 手順 3、 3の画像 1 Squier Strat Guitar Pickups Replacement: 手順 3、 3の画像 2 Squier Strat Guitar Pickups Replacement: 手順 3、 3の画像 3
    • Lift up the pickup guard gently.
    • Flip the pickup guard to expose the wiring.
    • Place a towel underneath the pickup guard to protect your guitar's body.
    • Potential for device damage: Do not use excessive force when lifting the pickup guard.
  4. Squier Strat Guitar Pickups Replacement: 手順 4、 2の画像 1 Squier Strat Guitar Pickups Replacement: 手順 4、 2の画像 2
    • Take note of where each pickup is wired.
    • Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
    • Pickups are usually wired to the potentiometers and pickup selector switch.
  5. Squier Strat Guitar Pickups Replacement: 手順 5、 2の画像 1 Squier Strat Guitar Pickups Replacement: 手順 5、 2の画像 2
    • Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
    • Desolder the pickups from the potentiometers.
    • Potential for device damage: Excessive heat from the soldering iron can damage components.
  6. Squier Strat Guitar Pickups Replacement: 手順 6、 2の画像 1 Squier Strat Guitar Pickups Replacement: 手順 6、 2の画像 2
    • Flip the pickup guard back to its original position.
    • Remove the screws holding the pickups to the pickup guard.
  7. Squier Strat Guitar Pickups Replacement: 手順 7、 2の画像 1 Squier Strat Guitar Pickups Replacement: 手順 7、 2の画像 2
    • Flip the pickup guard to reveal the wiring.
    • Remove the pickups from the pickup guard. They should come out very easily.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Ion
メンバー登録日: 09/29/15
479 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-5, Green Fall 2015 Cal Poly, Team 10-5, Green Fall 2015人のメンバー
CPSU-GREEN-F15S10G5
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 78
今までの合計 7,023
