メインコンテンツにスキップ
Spy Gear Video Walkie Talkies Camera Replacement
必要な工具と部品
  1. Spy Gear Video Walkie Talkies Camera Replacement, Top Cover: 手順 1、 1の画像 1
    • Remove the battery cover by removing the P1 Philips screw.
    • Remove the 3 AA batteries by hand.
  2. Spy Gear Video Walkie Talkies Camera Replacement: 手順 2、 1の画像 1
    • Unscrew Top Cover with a 3mm Triangle driver bit from the Driver Kit.
  3. Spy Gear Video Walkie Talkies Camera Replacement: 手順 3、 1の画像 1
    • Use Opening Tool to release barbed latch on top cover.
  4. Spy Gear Video Walkie Talkies Camera Replacement: 手順 4、 1の画像 1
    • Release pilot studs near the hinge with Metal Spudger.
  5. Spy Gear Video Walkie Talkies Camera Replacement: 手順 5、 1の画像 1
    • Once the Top Cover is free, you will have full access to the circuitry.
  6. Spy Gear Video Walkie Talkies Camera Replacement, Camera: 手順 6、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use Tweezers to remove the side button.
  7. Spy Gear Video Walkie Talkies Camera Replacement: 手順 7、 2の画像 1 Spy Gear Video Walkie Talkies Camera Replacement: 手順 7、 2の画像 2
    • Release the zero insertion force (ZIF) connector.
    • Pull the ribbon cable away carefully.
  8. Spy Gear Video Walkie Talkies Camera Replacement: 手順 8、 1の画像 1
    • With the ribbon cable free from obstructions, use a Prying Tool to release the circuit board from the guide studs.
  9. Spy Gear Video Walkie Talkies Camera Replacement: 手順 9、 1の画像 1
    • With a plastic Prying Tool, separate the screen from the mounting tray.
    • Adhesive between the layers may provoke damage to the screen or tray. Take your time.
  10. Spy Gear Video Walkie Talkies Camera Replacement: 手順 10、 1の画像 1
    • Once the screen is completely folded away from the mounting tray, release it from the circuit board by hand.
  11. Spy Gear Video Walkie Talkies Camera Replacement: 手順 11、 1の画像 1
    • Release the back of the mounting tray using a plastic Pick to unhook the barb from the circuit board.
  12. Spy Gear Video Walkie Talkies Camera Replacement: 手順 12、 1の画像 1
    • Now remove the mounting tray complete with camera and ribbon cable attached by sliding away from the screen.
    • You must not damage the screen or screen ribbon cable in this step.
  13. Spy Gear Video Walkie Talkies Camera Replacement: 手順 13、 1の画像 1
    • Discard faulty camera and mounting tray.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
James French
メンバー登録日: 02/15/16
151 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 7-7, Wilson Spring 2016 IUPUI, Team 7-7, Wilson Spring 2016人のメンバー
IUPUI-WILSON-S16S7G7
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 16
今までの合計 700
