メインコンテンツにスキップ
Sprint Sanyo RL-4920 Display Replacement
必要な工具と部品
  1. Sprint Sanyo RL-4920 Display Replacement, Back of Phone: 手順 1、 1の画像 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: 手順 2、 2の画像 1 Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: 手順 2、 2の画像 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Display Replacement, Screws: 手順 3、 2の画像 1 Sprint Sanyo RL-4920 Display Replacement, Screws: 手順 3、 2の画像 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: 手順 4、 1の画像 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: 手順 5、 1の画像 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Display Replacement, The Front Case: 手順 6、 1の画像 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Display Replacement, Display: 手順 7、 2の画像 1 Sprint Sanyo RL-4920 Display Replacement, Display: 手順 7、 2の画像 2
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Display Replacement: 手順 8、 2の画像 1 Sprint Sanyo RL-4920 Display Replacement: 手順 8、 2の画像 2
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Display Replacement: 手順 9、 2の画像 1 Sprint Sanyo RL-4920 Display Replacement: 手順 9、 2の画像 2
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Display Replacement: 手順 10、 2の画像 1 Sprint Sanyo RL-4920 Display Replacement: 手順 10、 2の画像 2
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Patrick Olmstead
メンバー登録日: 10/22/13
240 ポイント
2のガイドは作成済み
チーム
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S13G5
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 9
今までの合計 249
