はじめに
Most gravity flush toilets retain a small amount of water in the tank after draining. If there is still water in the bottom of your toilet tank after following our Draining a Toilet Tank guide, you may need to remove the excess water with a sponge.
必要な工具と部品
Use a sponge to soak up and remove any remaining water from the toilet tank.
Periodically squeeze the excess water from the sponge.
もう少しです!
ゴール
ある他の人がこのガイドを完成しました。
