はじめに
This guide is the basis for all repairs of the SRS-XB40 speaker. In order to get inside the speaker to fix any broken or faulty parts, you will need to complete this guide first. When taking apart the plastic cover on the sides of the speaker, you will hear what sounds like cracking, but it is just double sided tape holding the pieces on so don't worry if you hear some cracking sounds.
必要な工具と部品
Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
3 の人々がこのガイドを完成させました。
