メインコンテンツにスキップ
Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260
必要な工具と部品
  1. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Batteria: 手順 1、 3の画像 1 Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Batteria: 手順 1、 3の画像 2 Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Batteria: 手順 1、 3の画像 3
    • Premere con le dita entrambe le linguette di sgancio della batteria verso l'esterno e sollevare la batteria dal computer.
    Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
    ColmillodeChile - 返信
    Besides using WD 500GB models, are the WD 640GB and WD 750GB (the 9.5mm thickness model) good to go for? I am still considering as I have heard from other websites on the computer does not draw enough power to power up the 640 and 750 as it has the clicking sound and the rainbow keeps appearing. Anyone has install one before yet?
    Please advice. Appreciated! Thanks a million to all the Mac gurus out there!
    Danny Lim -
    ColmillodeChileからの引用:
    What is this about removing the PRAM battery causing a reinitialization of the HDD? For serious?
    Adrian - 返信
    No, that's nonsense
    max damage -
    Adrianthomaspreからの引用:
    Wait, I misunderstood you. I thought the comment was directed at the PRAM battery removal page. Silly me.
    Nevermind. Yes, it is always a good idea to backup one's data before doing stuff like this. I never do, and have never had any problems, but it's still a good idea.
    Adrian - 返信
    The two screws removed in step 3 should not be mixed with screws in steps 5 through 7. Though similar, they are actually slightly shorter and have a bigger head. If you put the longer screws back in here when reassembling, the button to unlatch the top will not work properly.
    Doug - 返信
    Dougからの引用:
    I think you may have commented on the wrong page. This page only has 3 steps, and the screws are removed in step 2, not 3.
    (MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement)
    Don - 返信
    I'm not sure how the user notes get attached to the various procedures here, but my comment does seem to show up properly when viewing the steps for Hard Drive Replacement. However, the number of the step may be off if viewed as part of another procedure.
    Donからの引用:
    Doug - 返信
  2. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione della schermatura della memoria RAM nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 2、 2の画像 1 Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione della schermatura della memoria RAM nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 2、 2の画像 2
    • Rimuovere le tre viti con testa a croce da 2 mm dallo sportello della memoria.
    • Sollevare lo sportello della memoria affinché sia possibile prenderlo e farlo scorrere verso di sé, estraendolo dall'alloggiamento.
    These screws are different from the rest, they should be kept separate from the others.
    foregoing-celery - 返信
    Replacing RAM on an A1226: The instructions said Phillips #00, but the screwdriver that fit the RAM Shield screws for me was a Phillips #0.
    dlyons - 返信
    Concur, my screws were Phillips #0 as
    Lee Haelters - 返信
  3. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione del case superiore nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 3、 1の画像 1
    • Rimuovere le due viti con testa a croce da 2,8 mm nello scomparto della batteria in prossimità della chiusura.
    Keep these two Philips screws separate. The screws are approximately 0.5mm shorter in length. When using one or two of the other longer screws in the battery compartment when reassembling, the lid will not open because the screw(s) do yam the lid button.
    Peter van Nes - 返信
    I had a logic board replaced by Apple (bad nVidia GPU), and believe it or not the Apple tech mixed up the screws. My latch did not work as good until I discovered and swapped the misplaced screws.
    madmaxmedia - 返信
    No believe it or not about it! I had same board replacement job done, and a screw was angled and crossthreaded, and the memory cover was hacked into place with insulating sheet lifted and crumpled.
    Lee Haelters -
    I removed the memory here as you would normally if you were changing it.
    Mike Matthias - 返信
    Use #00 phillips bit
    Jace - 返信
  4. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 4、 1の画像 1
    • Rimuovere le 6 viti seguenti:
    • Due viti Torx T6 da 10 mm su entrambi i lati dello slot RAM.
    • Quattro viti con testa a croce da 14,5 mm lungo il cardine.
  5. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 5、 1の画像 1
    • Rimuovere le quattro viti con testa a croce da 3,2 mm dal lato della porta del computer.
    If you are using a muffin pan to keep removed parts separate (a method I recommend highly), note that Steps 5, 6, and 7 involve removing the same size screw—and thus you can put them all in the same pile. This is unlike just about every other part you will remove during this procedure.
    Matt McCaffrey - 返信
    Using shot glasses!
    peterbcpa -
    If you are a mac newbie like me take care when you reassemble not to insert a screw in the DVI display port screw holes (shame). I cannot manage to get it out anymore.
    tai manu - 返信
    I did the same thing once, and eventually got it out. Try tweezers, a screwdriver, magnets, holding the MBP on its side so gravity is working with you, etc. Eventually the little bugger will come out, you just have to keep working at it.
    madmaxmedia -
    It would be a good idea to put some sticky tape on those two DVI display port holes, so that you never make the mistake to insert (when reassemble) any of the screws!
    genik - 返信
    RE: Misplaced Screws in the DVI port, I was upgrading an early 2008 MacBook Pro with an SSD to get some more life out it, and sure enough, misplaced one of these small screws into the DVI port upon reassembly. Screwdrivers, shaking, gravity... nothing worked. UNTIL I went to my dad's house and his super-comprehensive workbench, where he found a small, high-pull magnet and the little bugger flew right out. Refrigerator magnets won't cut it, you will need a more powerful magnet, such as these: http://www.kjmagnetics.com/products.asp?...
    Hope this helps someone... it was an easy solution to a frustrating problem
    John Lee - 返信
  6. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 6、 1の画像 1
    • Ruotare il computer di 90 gradi e rimuovere le viti con testa a croce da 3,2 mm dalla parte posteriore del computer.
  7. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 7、 1の画像 1
    • Ruotare il computer di 90 gradi e rimuovere le viti con testa a croce da 3,2 mm dalla parte laterale del computer.
  8. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 8、 3の画像 1 Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 8、 3の画像 2 Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 8、 3の画像 3
    • Non rimuovere il case superiore rapidamente, poiché è collegato alla scheda logica tramite un cavo piatto.
    • Sollevare il case dalla parte posteriore e, mediante le dita, liberarlo progressivamente dai lati. Dopo aver liberato i fianchi, potrebbe essere necessario inclinare il case verso l'alto e verso il basso per liberare la parte anteriore del case superiore.
    • Sono presenti quattro levette di plastica sopra lo slot del DVD e in alto e a sinistra del sensore infrarossi. Queste levette potrebbero essere difficili da sganciare senza fare leva. Inoltre, potrebbe essere difficile riagganciarle durante il riassemblaggio.
    • Suggerimento di riassemblaggio: Premere fortemente sulle estremità del case superiore verso il basso fino a sentire un schiocco per mettere le legame nelle corrispondente fessure.
    • Suggerimento di riassemblaggio: le due legame DVD della metà si raramente agganciano senza aiuto.
    • Attenzione non di distorcere il quadro attorno il DVD fianco con una pressione al ribasso. Sostenere il quadro: inserire una spatola di plastica negli i fianchi di DVD direttamente sotto la locazione delle legame fino è sicuro. Doppo, premere verso il basso fino a sentire un schiocco.
    The clips above the DVD slot (below the deck palm rest) are an absolute bear. They're hard to get released, and even harder to get back locked when you reassemble. (I've read to tilt the deck toward you when reassembling, inserting the front edge first, and press about an inch back from the edge to get all the front clips locked first before lowering the rest (back) of the deck.) No success for me yet, best of luck.
    sonofray - 返信
    I thought these two videos did an excellent job of showing the technique of removing and replacing the drive.
    MacBook Pro/PowerBook Keyboard Replacement (Part 1 of 3):
    http://www.youtube.com/watch?v=jUonF9OSv...
    MacBook Pro/PowerBook Keyboard Replacement (Part 3 of 3):
    http://www.youtube.com/watch?v=JWeFXWXpp...
    After watching that, I had the keyboard replaced in 2 minutes.
    Chris -
    the technique you describe of putting the front down first, is exactly what I did and it worked well
    dillonsavard -
    Those clips on the front edge are very challenging. I have a set of nylon pry tools that are for taking apart car dashboards without scratching the vinyl or plastic. I was able to get a long one in from the side and twist it which freed the clips without damaging the plastic on the upper case or the aluminum on the lower case.
    Putting it back together presented another challenge. When I first re-assembled it I think I pushed too hard over the DVD slot and accidentally bent the metal down. I was able to bend it back up using a thicker part of those same nylon pry tools, and then i was able to get it snapped back down successfully. Had I known this would happen, I would have just put the nylon tool in the slot to reinforce the metal as I was snapping the case back down.
    Nick - 返信
    As everyone has said, the front clips by the DVD can be really tight. Use the spudger to pry the top and bottom halves apart. Slow work it in from one side to separate the top and bottom.
    When reassembling the case, work the front clips by the DVD drive back in first. Once you slide them back in, the rest of the case fits easily.
    Ted Wise - 返信
    i've used an old atm card, it works fine.
    rotarypot - 返信
    I had a lot of trouble with getting those clips to lock in place again when reassembling. The way I eventually did it was to wedge something into the front of the CD/DVD slot so that I wouldn't warp the laptop casing. I used the end of a pen; when wedged in the tip of the pen was the right height to not support the casing above and below the CD/DVD slot and not allow it to warp.
    I simply ensured the pen was aligned with one particular clip, lifted the laptop slightly, and squeezed the top and bottom edge of the laptop casing very firmly at that point. Each clip clicked in quite easily doing it this way. Just remember to move the pen (or whatever you are using) along to whichever clip you are clicking in.
    David - 返信
    You're on the right track David. But what works really good is something that gets more surface area contact than the pen--I carefully insert a stack of 3" square post-it notes about 3/8" into the slot. And because they're stacked, you can easily add/subtract post-its to get as tight a fit as possible. Then, assuming you have everything lined up, use quite a bit of downward pressure. You should hear a few snaps as the clips reseat.
    Davidからの引用:
    John Kassler Niemann - 返信
    John, I didn't think of that. But yeah you are right, it would give it a lot more support.
    David - 返信
    I have none of the problems above just was very careful, but inserting the palm rest in first does most of the work , gently does it looking at the alinement of the clips as you go straight in she goes!
    swissgrip - 返信
    I would agree with everyone that the clips above the DVD drive are very temperamental. They came off easily for me but were a pain getting to clip back in place correctly.
    Make sure you have the front clipped on securely before screwing the case back together otherwise the lid will not close properly.
    Nicolas - 返信
    I have taken apart quite a few laptops but this is my first Mac. This confirms my statements, to anyone that will listen, that these are the most "exquisite" machines ever produced. I just performed these HDD Replacement steps and with appropriate fear and trepidation popped the clips off. It would have been very helpful if someone had mentioned that they come straight up. I wasn't sure so I wiggled and (carefully) pried with the spudger until one of them went "POP". The credit card idea was helpful but my card was pretty soft so I didn't dare use it with too much force. When I got the top cover loose I just leaned it back against the screen so as not to take a chance on damaging the cable. Reassembly was according to the notes, but again the spudger was perfect if inserted into the drive slot (careful on the felt!) to support the base of the clips. Thanks to all for the notes. BTW; Prayer helps!
    mikedotten331 - 返信
    There is a fifth plastic clip between the IR sensor and the screw hole. (ie. 1 cm left of the IR sensor)
    On the top of the case mark the center of each of the four clips that are over the CD slot and the one clip to the left of the latch with a pencil. When re-installing the top case apply pressure over the clip to the left of the latch until you hear a snap. For the four clips over the CD slot, upend the entire case. Then insert the flat end of the spudger into the CD slot under the center of each clip. Apply pressure from the top of the case while providing support with the spudger in the CD slot until the clip snaps in. This will minimize the chances of bending the CD slot which would prevent CDs from ejecting.
    danno - 返信
    Take care reassembling new the DVD drive. It's easy to bend the top piece of metal down (the one that engages the clips) and your DVD can get stuck occasional ejecting. Very annoying. Maybe give it a little prophylactic bend upward. I placed a blunt letter opener in the slot and torqued it, while applying downward pressure from the top deck... This allowed the clips to engage nicely without bending this piece down.
    davidkkim - 返信
    I use the iSesamo tool to loose the clips, its a very good tool for this and many other things (I don´t work for iSesamo or iFixit hehe).
    araujogac - 返信
    i've used both of my inch nails, it works fine as well. no trouble to report.
    Caroline Masson - 返信
    i used a pry tool i had left over from replacing the screen on my iphone, any flat stiff item, like a credit card would work. watch the youtube video linked above, http://www.youtube.com/watch?v=jUonF9OSv..., skip ahead in the video to 4:57 where you see her use a pry tool. I had no problem separating and reassembling this section. Only issue i had was the two screws in the battery area. Only one of them would grab, so I left the other one out.
    owenmhv - 返信
    Here is an additional video showing how to remove the cables for both the left and right fans. At time 2:00 in the video he starts to work on the left fan. This video will help prevent you from attempting to detach the cables incorrectly.
    http://www.youtube.com/watch?v=apn3j3mAR...
    owenmhv - 返信
    I've opened these up many, many times, and by far the easiest method I have found to disengage the front clips is as follows:
    Lift up the top case by the rear corners near the hinge, keep lifting so the top case is tilting towards you. You will feel some resistance, but keep lifting and you will hear the clips disengage with a 'snap'. Doing it this way should not bend the top case metal or loosen the spacing between the top case metal and plastic trim. The clips will not break, they will still engage when you put the top case back on.
    It basically takes me 5 or 10 seconds to take off the top case now, and the case goes back on nice and tight as before.
    YMMV and all that, but that's my experience.
    madmaxmedia - 返信
    Thank you for all the advance warnings, I had no issues with replacing the case. It just snapped into place with a little help from the spudger.
    acuella - 返信
    You're welcome! I was the one who added the spudger tips, as I had a devil of a time making the DVD drive clips snap back into place without one when I followed this guide.
    CaptFrost -
    Hello,
    I didn't have much problems reassembling the MacBook. Thanks a lot!
    For the hard reassembly part with the clips: I pushed quite hard with both thumbs directly over the place where the clips are. You need to figure out exactly where they are, but it worked well.
    I repeat it to make it clear: I pushed from the top on the location under which the clip sat, with two thumbs after having checked that the lid was well in place.
    My tools were one spudger and a basic tech toolkit from iFixit.
    Thanks a lot!
    momogingins - 返信
    I had not problem easing GENTLY the top case from the computer even around the DVD but I didn't understand how easy it was to disconnect the top case from the mother board. TAKE CARE HERE. It will make reassembly much easier it YOU get to disconnect the plug. See my note on step nine
    reb - 返信
  9. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 9、 2の画像 1 Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 9、 2の画像 2
    • Scollegare il cavo piatto della tastiera e del trackpad dalla scheda logica, rimuovendo il nastro secondo necessità.
    • Nota: è possibile sostituire il disco rigido senza scollegare la tastiera dal case, tuttavia occorre tenerla in posizione sollevata affinché non sia d'intralcio e consenta di rimuovere il disco rigido con entrambe le mani.
    • Fare attenzione durante la rimozione del cavo piatto della tastiera e del trackpad e verificare che la parte posteriore del case superiore sia sganciata dalla zona in prossimità del cardine. I ricettacoli delle viti su entrambi i lati della tastiera sono facilmente soggetti a piegature accidentali.
    • Rimuovere il case superiore.
    If you does not have the spudger, use the Dremel to file a wooden piece
    (Chinese stick maybe) to transform in a spatula. Works fine for me
    If you don't have the magic "spudger," try using a plastic (eating) knife.
    jpkjpkjpk - 返信
    I read that you can actually also use the corner of a credit card. I didn't have a spudger and this worked perfectly for me. If you hold the card quite close to the corner and it has just the right amount of flex.
    David - 返信
    You may be able to unplug the ribbon connector by lifting each end of the tape.
    MrSafety - 返信
    Where can I get the cable from step 9 above?
    just broke it!
    Derry Manley - 返信
    That cable is attached to the upper case. It can be found here for the A1226 and here for the A1260.
    Andrew Bookholt -
    To unplug the cable, pull the black connector straight up from the logic board.
    Robert MacLeay - 返信
    These are instructions for the right Fan. Step 9 mentions the hard drive not the right fan.
    karen - 返信
    I didn`t need to unplugged the cable to change the right fan. As Karen wrote above, it is for a fan to change not necessary.
    I chose not to disconnect this ribbon cable. I used a chopstick to prop open the front panel; just gently place in lower right corned of case and upper right corner inside the top panel. Saves the risk of disconnecting.
    jimmora - 返信
    I didn't look well before the plug connecting top case to motherboard (see my note in step 8). When it came time for assembly it took a while for me to figure out when the plug connected in the motherboard. Take care on step 8 so that YOU have to make the disconnection in step 9. Then reassembly on this step will be much easier.
    reb - 返信
    Step 9, 2007 Mac Book Pro right fan replacement. It’s not necessary to disengage the keyboard ribbon, you can just tilt the upper shell back and support it against the screen. Be sure not to put tension on the ribbon and to check that the ribbon “plug” is seated securely on the base before reinstalling the top shell.
    These instructions were really great. For $15 I got a used fan off eBay and a Torx T6 driver and Phillips 00 driver from the hardware store. Thanks also for the comment about marking where the plastic clips are by the DVD and IR slot with pencil. When reassembling I slotted a piece of wood (kebab skewer) into the DVD slot and pressed down on the pencil mark with the eraser end of the pencil.
    My 10 year old MacBook Pro is going strong. Thanks for these very much. It was fun to do as well.
    Kirsten - 返信
    Hello, I have a MacBook like this but I have seen that in the part of the RAM on the right there is an elongated chip, I don't have it, that could cause the problem of no connection, what is the name of that chip, thank you
    Trepas - 返信
  10. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione dell'unità ottica nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 10、 1の画像 1
    • Utilizzare l'estremità piatta di un inseritore per scollegare il cavo piatto arancione dell'unità SuperDrive dalla scheda logica, rimuovendo il nastro secondo necessità.
  11. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 11、 2の画像 1 Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 11、 2の画像 2
    • Rimuovere le 4 viti seguenti:
    • Due viti con testa a croce argentate da 3,3 mm su entrambi i lati dell'unità SuperDrive.
    • Una vite Torx T6 argentata da 4,7 mm dall'angolo superiore sinistro dell'unità.
    • Una vite con testa a croce nera da 6,2 mm dall'angolo superiore destro dell'unità.
    • Sollevare l'unità ottica e rimuoverla dal computer.
    The bent metal clip on the right hand side can make the drive seem stuck, even once all 4 screws are removed. You can tilt the drive forward and gently wiggle it up and down to see the clip coming out, and pull by the clip to remove the drive.
    Matt Gorbet - 返信
  12. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 12、 2の画像 1 Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 12、 2の画像 2
    • Le nuova unità ottica è già dotata di staffe, occorre solo trasferire il cavo dati.
    • Rimuovere le due viti con testa a croce argentate che fissano la staffa di montaggio al lato sinistro dell'unità ottica.
    • Ruotare l'unità e scollegare il cavo piatto arancione dall'unità ottica.
  13. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 13、 1の画像 1
    • Rimuovere le due viti con testa a croce che fissano la staffa di montaggio al lato posteriore dell'unità ottica.
  14. Sostituzione dell'unità ottica del MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: 手順 14、 1の画像 1
    • Ruotare l'unità e rimuovere le due viti con testa a croce che fissano la staffa di montaggio al lato destro dell'unità ottica.
    • Se l'unità ottica non è dotata di staffe di montaggio, occorre trasferire semplicemente le tre staffe metalliche argentate e il cavo piatto arancione a tale nuova unità.
終わりに
Per riassemblare il dispositivo, seguire queste istruzioni in ordine inverso.
162 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en it
100%
Oriane Petitさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
9人の作成者と共同で作成されました。
Walter Galan
694,676 ポイント
1,203のガイドは作成済み
2 件のコメント
In step 5 suggestion, muffin pan for parts, I used 500Ml (1 cup) yogurt containers, about 10 of them and numbered each one with the corresponding dis-assembly/re-assembly step, and my replacement of the CD RW-DVD-Rom to a DVD R-RW DL/CD RW drive in my Macbook went without a hitch. It took me about 2 hours, with breaks, and I also used a Magnifier Lamp along with approved, magnetic tip screwdriver bits, which made the whole thing a lot easier.
capone99 - 返信
Since the optical drive was not available from iFixit or Amazon I bought from a company on eBay. After carefully checking the model number of my Mac A1226 I found that the original optical drive could not be found but that there was a slightly new optical drive model which would work with my Mac. Completely compatible and works great. The screw holes were in the right places. No problems following the iFixit guide as long as you have very careful attention to detail. To obtain the replacement optical drive check out this item/seller: https://www.ebay.com/itm/282356807784.
Kevin - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 14
過去 30 日: 62
今までの合計 152,871
