はじめに
Sostituisci l'ottica laser dell'unità disco. La sostituzione del laser richiede di avere o acquistare un nuovo laser.
必要な工具と部品
Utilizza il bordo piatto di uno spudger di metallo per estrarre i coperchi delle otto viti piatte.
Rimuovi le seguenti otto viti che fissano il coperchio superiore alla cassa inferiore:
Quattro viti a croce da 55,4 mm
Quattro viti a croce da 18,0 mm
Rimuovi le quattro viti a croce da 6,4 mm che fissano il coperchio superiore dell'unità disco ottico.
Solleva e rimuovi il coperchio dall'unità disco ottico.
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
34 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Simoneさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
8 件のコメント
just did the laser replacement, however the playstation still identifies "no data" when game is inserted. it says "reading disk" for a few seconds then nothing else happens. thought?
Have you removed the security solder blob? All new Lenses have this somewhere in the circuitry.
I noticed that many times when you replace a lens it throws of the rotary motor. Some ps2 consoles have only 1 hex adjustment yet others have 2. If you have the covers off and just replaced the lenses you should always plug it back in w/ the top off still and adjust it until you see the disc spinning rapidly and laser is moving back and forth. Another way for calibrating is to remove said disc and if lens and ribbon move all the way forward and all the way back 3 or more times then you are almost done. At that point plug in tv chord and place in a disc if the PlayStation 2 logo comes on and disappears in less than 3 seconds carefully replace all parts and your good to go.
Could you please add the parts you would need to replace this to the parts portion.
Nice guide by the way.
