メインコンテンツにスキップ
Sophix TAB-730g Screen Replacement
必要な工具と部品
  1. Sophix TAB-730g Screen Replacement, Screen: 手順 1、 1の画像 1
    • Take off the screen protector and the screen on the tablet.
    • Wedge a plastic opening tool between the screen protector and the screen.
    • Using leverage, move the tool around the entire front face of the tablet in order to break the adhesion.
    • Continue until the top screen protector pops off.
  2. Sophix TAB-730g Screen Replacement: 手順 2、 1の画像 1
    • The screen is attached to a ribbon cable in the lower left hand corner marked in the picture (see highlighted area in picture).
    • The back cover of the device will need removed before continuing.
  3. Sophix TAB-730g Screen Replacement: 手順 3、 1の画像 1
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  4. Sophix TAB-730g Screen Replacement: 手順 4、 1の画像 1
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  5. Sophix TAB-730g Screen Replacement: 手順 5、 1の画像 1
    • Remove the tape covering the ribbon cable's (which connects to the front of the screen) insertion point on the back of the device.
    • This will allow you access to remove the ribbon cables that is hindering you from taking off the screen.
  6. Sophix TAB-730g Screen Replacement: 手順 6、 1の画像 1
    • Remove the ribbon cable by placing your fingers on the outside of the ribbon closest to the port it goes into.
    • Flip the black switch up so the ribbon cable will be able to come out.
    • Gently pull the ribbon cable out of the port.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
JT Hiquet
メンバー登録日: 09/29/16
333 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-3, Harley Fall 2016 IUPUI, Team 2-3, Harley Fall 2016人のメンバー
IUPUI-HARLEY-F16S2G3
4 メンバー
6のガイドは作成済み
コメント 1 件
Where to buy a replacement screen for a azpen A848 projector tablet
gayle almond - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 511
