この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Make sure you can explore the Xplod very well.
必要な工具と部品
Press down the release button on the bottom left corner of the face plate.
Then remove the face plate carefully.
この手順で使用する道具:Phillips #0 Screwdriver$5.49
Using the Phillips #0 Screwdriver, unscrew the 4 (length - 11.11mm) screws on the front screen.
この手順で使用する道具:Heavy-Duty Spudger$4.99
Insert the flat end of the Heavy-duty Spudger into the opening you created.
Slide it to the right carefully, until you feel the screen pop off.
Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
To remove the LCD, please refer to the iFixit soldering guide.
Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
