メインコンテンツにスキップ
Sony Xperia go Front Glass/Digitizer Replacement
必要な工具と部品
  1. Sony Xperia go Front Glass/Digitizer Replacement, Front Glass/Digitizer: 手順 1、 1の画像 1
    • Show here is a Sony xperia go with broken glass digitizer.
  2. Sony Xperia go Front Glass/Digitizer Replacement: 手順 2、 3の画像 1 Sony Xperia go Front Glass/Digitizer Replacement: 手順 2、 3の画像 2 Sony Xperia go Front Glass/Digitizer Replacement: 手順 2、 3の画像 3
    • Remove backcover, and remove all screws.
    • 1 Torx screw
    • 7 star screws (don't know their name)
    • Note some of the screws have rubber spacers, use caution to avoid breaking them. (See second Picture in this step)
    • Remove sim card tray. (See third picture)
  3. Sony Xperia go Front Glass/Digitizer Replacement: 手順 3、 3の画像 1 Sony Xperia go Front Glass/Digitizer Replacement: 手順 3、 3の画像 2 Sony Xperia go Front Glass/Digitizer Replacement: 手順 3、 3の画像 3
    • Now the front can be seperated from the back.
    • CAUTION! there are some doublesided tape blocks situated on top of the connectors to the digitizer.
    • Use spudger to seperate these carefully from eachother.
    • Now you can open the phone sideways. Once opened, please disconnect the battery, marked on third Picture with a yellow circle.
    • Now you can disconnect digitizer cable and screen cable, marked with red circles on third picture.
    • Now you will be able to remove the front from the back of the phone.
  4. Sony Xperia go Front Glass/Digitizer Replacement: 手順 4、 2の画像 1 Sony Xperia go Front Glass/Digitizer Replacement: 手順 4、 2の画像 2
    • Using a heat gun, heat around the edges and seperate the glass from the front cover. Work from bottom up.
    • Note the digitizer cable runs through a small hole behind the lcd, in the top of the phone.
    • When the glass is seperated, carefully lift the lcd a bit, to get the digitizer cable through the hole.
    • To protect the lcd from residue and fingerprints, cover it with masking tape, until you are ready to seal the glass to the cover.
    • When you have prepared new adhesive tape and the digitizer cable has been pulled through the hole to the backside of the phone.
    • Remove the masking tape from the lcd, and using some canned air, blow away dust and close the glass cover.
    • Finally reverse the disassembly and enjoy.
終わりに
22 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
lassedollerup
メンバー登録日: 03/31/13
620 ポイント
1ガイドが承認済み
10 件のコメント
can u make guide for installing loudspeaker please
anep tg - 返信
Nice guide but, I only want to change front cover and back cover, because it´s damaged . If Open my xperia go, I will lost water proof and dust proof?
Juliano - 返信
Hello sorry for my late reply.
I haven't had the chance to replace the loudspeaker, but earpiece is a square block, that you can pry out and replace, after you have seperated the front from the back.
lassedollerup - 返信
Dissasembly will most likely break waterproof. Haven't tested.
lassedollerup - 返信
Nice guide and easy to follow. Thank you.
alex jesty - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 40,110
