メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Xperia ZL Volume and Power Button Replacement
必要な工具と部品
  1. Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: 手順 1、 2の画像 1 Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: 手順 1、 2の画像 2
    • Open the small cover on the bottom of the rear cover.
    • Peel back the sticker under the cover to reveal two screws.
    • Remove the two JIS #00 screws from the back of the phone.
    FixBotに聞いてみる
  2. Sony Xperia ZL Volume and Power Button Replacement: 手順 2、 1の画像 1
    • Remove the six screws from the phone using a JIS #00 screwdriver.
    FixBotに聞いてみる
  3. Sony Xperia ZL Volume and Power Button Replacement: 手順 3、 1の画像 1
    • Use a nylon spudger to disconnect the seven connectors.
    • Never use a metal spudger around the battery. Use plastic or nylon prying tools instead.
    FixBotに聞いてみる
  4. Sony Xperia ZL Volume and Power Button Replacement: 手順 4、 1の画像 1
    • The last connector is located under the back sticker.
    • Peel the sticker back to get access of the connector and use a nylon spudger to disconnect it.
    FixBotに聞いてみる
  5. Sony Xperia ZL Volume and Power Button Replacement: 手順 5、 1の画像 1
    • Remove the camera assembly using an opening tool or spudger.
    FixBotに聞いてみる
  6. Sony Xperia ZL Volume and Power Button Replacement: 手順 6、 1の画像 1
    • Remove the motherboard with an opening tool or spudger.
    FixBotに聞いてみる
  7. Sony Xperia ZL Volume and Power Button Replacement: 手順 7、 1の画像 1
    • Remove the battery with a plastic opening tool or spudger.
    • The battery has adhesive tape that connects it to the phone which makes it difficult to pry out.
    • Never use metal prying tools on the battery. Be sure to use a plastic prying tool to avoid puncturing the battery.
    FixBotに聞いてみる
  8. Sony Xperia ZL Volume and Power Button Replacement: 手順 8、 1の画像 1
    • Detach the plastic covering from the top side of the phone by hand.
    FixBotに聞いてみる
  9. Sony Xperia ZL Volume and Power Button Replacement: 手順 9、 1の画像 1
    • Pry off the signal receptor and front camera using an opening tool or spudger.
    • The signal receptor has adhesive tape underneath so proceed with caution when prying.
    FixBotに聞いてみる
  10. Sony Xperia ZL Volume and Power Button Replacement: 手順 10、 1の画像 1
    • Remove the volume and power button with an opening tool or spudger.
    • For replacement, this component comes as a whole. If the volume and power button do not work, they will need to be replaced together.
    FixBotに聞いてみる
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Liam Kanaley
メンバー登録日: 11/03/15
433 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 UMass Dartmouth, Team 1-7, Bhusal Fall 2015人のメンバー
UMASSD-BHUSAL-F15S1G7
3 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 50
今までの合計 2,408
