メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If your Sony Xperia Z5 Compact fails to charge or sync data, you may need to change new charging port flex. Here is the process to replace the USB board.
  1. Power off and remove SIM card tray. Power off and remove SIM card tray.
    • Power off and remove SIM card tray.
  2. Heat up the back cover to soften the adhesive. Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath. Remove back cover.
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Remove all 10 Phillips screws. Disconnect NFC clip and flashlight clip.
    • Remove all 10 Phillips screws.
    • Disconnect NFC clip and flashlight clip.
  4. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  5. Remove the plastic bracket. Pry up and remove back frame. Pry up and remove back frame.
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  6. Remove front camera. Remove front camera. Remove front camera.
    • Remove front camera.
  7. Remove rear camera. Remove rear camera. Remove rear camera.
    • Remove rear camera.
  8. Remove loudspeaker. Remove loudspeaker. Remove loudspeaker.
    • Remove loudspeaker.
  9. Release charging port connector. Remove plastic protective bar. Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  10. Remove charging port flex.
    • Remove charging port flex.
終わりに
8 の人々がこのガイドを完成させました。
Witrigs
メンバー登録日: 2015年11月24日
65,211 ポイント
386のガイドは作成済み
4 件のコメント
How do you reseal the back cover on to the phone?
bmw0208 - 返信
You can take a new back cover sticker to reseal.
Witrigs -
Are there other parts in this procedure that need to be resealed, e.g. Loudspeaker?
Bernhard - 返信
Hi great guide thank you, made it less daunting than I expected to repair my own phone, and cheaper than getting it repaired by someone else! Phone is as good as new, though I could probably do with some new adhesive, as the guitar picks mess it up a fair bit. You did mention including adhesive though so fair play!
@bernhard you don’t need to reseal anything apart from the back, although the camera flash does have a small amount of adhesive behind it when you lift that part up, though doesn’t seem to be messed up too much
Edward Barker - 返信
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 33
今までの合計 8,586
