1. Heat to soften back cover sticker. Place the suction cup and drag to open a gap. Insert into guitar pick.
    • Heat to soften back cover sticker.
    • Place the suction cup and drag to open a gap.
    • Insert into guitar pick.
  2. Slide the guitar pick to cut the sticker and remove the back cover. Slide the guitar pick to cut the sticker and remove the back cover.
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  4. Remove battery. Remove battery. Remove battery.
    • Remove battery.
  5. Remove signal flex.
    • Remove signal flex.
  6. Release magnetic charging flex with the motherboard. Get free the flex securing bracket from the hidden keys of mid frame. Remove the flex from several square stickers.
    • Release magnetic charging flex with the motherboard.
    • Get free the flex securing bracket from the hidden keys of mid frame.
    • Remove the flex from several square stickers.
まとめ
4 の人々がこのガイドを完成させました。
Sophia
メンバー登録日: 2014年03月25日
41,610 ポイント
62のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 2,684
