メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This is the replacement guide for Sony Xperia Z3 Dual as well as Sony Xperia Z3 front camera.
  1. Power off the phone and remove two SIM card trays before replacement.
    • Power off the phone and remove two SIM card trays before replacement.
  2. Heat to soften back cover adhesive sticker. Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker. Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker.
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker.
  3. Remove back cover carefully and avoid cracking the glass.
    • Remove back cover carefully and avoid cracking the glass.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  5. Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement. Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement. Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement.
    • Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement.
  6. Remove screws at first.
    • Remove screws at first.
  7. Remove three pieces of securing bracket. Remove three pieces of securing bracket. Remove three pieces of securing bracket.
    • Remove three pieces of securing bracket.
  8. Release all the connectors connecting with motherboard. Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful. Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful.
    • Release all the connectors connecting with motherboard.
    • Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful.
  9. Release the connector and pull out the flex at first, please be careful as you can. Remove the front camera finally.
    • Release the connector and pull out the flex at first, please be careful as you can.
    • Remove the front camera finally.
終わりに
2 の人々がこのガイドを完成させました。
Sophia
メンバー登録日: 2014年03月25日
42,869 ポイント
62のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 2,198
