メインコンテンツにスキップ
Sony Xperia Z3 Dual Back Cover Replacement
必要な工具と部品
ビデオの概要
  1. Sony Xperia Z3 Dual Back Cover Replacement, Back Cover: 手順 1、 1の画像 1
    • Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
  2. Sony Xperia Z3 Dual Back Cover Replacement: 手順 2、 1の画像 1
    • Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
  3. Sony Xperia Z3 Dual Back Cover Replacement: 手順 3、 1の画像 1
    • Insert guitar pick into the gap and slide to cut the sticker around the back cover.
  4. Sony Xperia Z3 Dual Back Cover Replacement: 手順 4、 1の画像 1
    • Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
  5. Sony Xperia Z3 Dual Back Cover Replacement: 手順 5、 1の画像 1
    • Remove the back cover easily. It comes with camera lens and NFC.
    • And you can place your new back cover, press the adhesive sticker and done the replacement.
    Can i back the back cover without using new adhesive sticker?
    Christia benedictcruz - 返信
終わりに
12 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sophia
メンバー登録日: 03/25/14
43,810 ポイント
62のガイドは作成済み
2 件のコメント
My Xperia z3 was broken back cover if I replace this cover, this waterproof features are still working or not? guys I need your suggestions
Winstonmary Dimagnaong - 返信
Are you sure that the replacement parts mentioned above would work for the Z3 DUAL as well? I believe it has a slightly different size or shape compared to the regular Z3
Shevek - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 21,124
