メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide shows you how easy to replace Sony Xperia Z3 back cover. And if the phone waterproof or not depends not only perfect operation but also the good back cover replacement parts.
ビデオの概要
  1. Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
    • Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
  2. Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
    • Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
  3. iPhone LCDスクリーン修理キット
    生涯保証付きの低コストオプション
    キット商品を見る
    品質ではなく、修理コストを削減しましょう。
    キット商品を見る
  4. Insert guitar pick into the gap and slide to cut the sticker around the back cover.
    • Insert guitar pick into the gap and slide to cut the sticker around the back cover.
  5. Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
    • Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
  6. Remove the back cover easily. It comes with camera lens and NFC.
    • Remove the back cover easily. It comes with camera lens and NFC.
    • And you can place your new back cover, press the adhesive sticker and done the replacement.
終わりに
12 の人々がこのガイドを完成させました。
Sophia
メンバー登録日: 2014年03月25日
42,562 ポイント
62のガイドは作成済み
2 件のコメント
My Xperia z3 was broken back cover if I replace this cover, this waterproof features are still working or not? guys I need your suggestions
Winstonmary Dimagnaong - 返信
Are you sure that the replacement parts mentioned above would work for the Z3 DUAL as well? I believe it has a slightly different size or shape compared to the regular Z3
Shevek - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 20,701
